Tazmantic
  1. Hi does any one have much experience of this LCD? with my J-LCD I could choose 0 pas but this one only seems to go to 1 so I'm presuming if I don't want assist I have to switch it off. Cheers
  2. This was the feedback..... BEWARE very suspicious cancelled sale when i ask why no key for bike and locks :D
  3. Oh I didn't win it I just went and looked lol the guy won it first time for £103 i think it was and has already left feedback
  4. Hi got any pics
  5. Won, then relisted then removed
  6. Managed to pick up a cheap 2nd hand morpheus labs M4s bracket and phone case so will give that a go, if it works ok for my needs will need to try get a couple more brackets (that seem to be out of stock everywhere)
  7. Measured cells again and each group is 4.15v and from the ground to each group the voltage rises by 4.15v (8.3v, 12.45v, 16.6v etc) till I get to the last set and 41.5v so its looking like the charger will only charge to 41.5v.
  8. Thanks so not to worry about the 5th led on the test button then though I’m sure it used to light, will have to see what happens after I’ve started using it again. but one thing I’ve noticed as it’s 36v should it not have 10 cell groups (10s) and thus should there not be 11 wires on the balance plug mine only has 9 wires?? cheers
  9. Pulled battery apart as soon as charge stopped and all cell groups measured 4.15v
  10. Thanks for all the info guys need one that will go on a motorbike too so some reading to do
  11. Thank you that's absolutely spot on I now know what I'm looking at thanks for taking the time to do that for me
  12. I do but 15,000 is a lot to trawl through and a lot of buying to get one thats tried and tested
  13. Thanks will try this later
  14. Hi thanks for the reply, sounds like it might be what I’m after as I’d like to fit the mount to my bike and motorbike and be able to easily mover the phone across as use the phone as a speedo. Do you have any pics, part numbers or links please. many thanks
