stever1957 started following Big Bear - Motor Gone? , Motor Blown Up? , Need New Front Wheel with Motor and 7 others
Motor Blown Up?
I imagine that these exposed wires at the motor now require some form of waterproof protection?
Motor Blown Up?
Actually, Woosh wrote: "You could use WAGO blocks as a temporary solution"
Motor Blown Up?
I imagine I'll have to make the joint waterproof somehow?
Motor Blown Up?
I see, thank you too
Motor Blown Up?
I see, thank you.
Motor Blown Up?
Well, while I'm waiting for my Wago connectors to arrive, I decided to connect them up. temporarily, with those white, nylon ones that you screw closed. I decided to try connecting just the three thick wires, and lo-and-behold, it works great! Thanks Nealh.
Motor Blown Up?
- Motor Blown Up?
We are talking about the connectors at the motor? I ask this because, when I connected them all up earlier, I found I was getting that 'juddering' again, until I noticed that the white wire had become disconnected. When I also connected the white wire, all was good.- Motor Blown Up?
Oh, many thanks.- Motor Blown Up?
Well, I connected all of the wires temporarily, by just twisting them together. The motor is fine and I rode the bike around the block. I just need to find a way of connecting all of these wires permanently, but so that they can be disconnected if required.- Motor Blown Up?
There is a delicious logic to your solution which, I fear, I might not have arrived at before I became mummified. I've cut off the connectors, stripped the wires and will get some heat-shrink before continuing. The wires are: red, blue, green, black, white and yellow. I imagine they must all be connected?- Motor Blown Up?
Okay. The smoke wasn't coming from the motor, it seems. The connector from the controller side is melted, with a pin from one connector now stuck in the hole of the other.- Motor Blown Up?
Thanks for that. I'll go and check that in the next half hour.- Motor Blown Up?
Hello again. I suppose when the motor starts to behave in a juddery fashion, then smoke comes out of it and then it stops working, but tries to, that means it's done for?- Front wheel with motor?
Wheel arrived, installed, dropouts not a problem. Lovely. Good old Woosh. - Motor Blown Up?
Back to top
