Garry Poulton started following flecc
Garry Poulton started following Woosh
What bike
Thanks, my regular ride which is 20 miles round trip has a couple of good hills and i only really need assistance on the hills. Most of the time i don't use any power.
What bike
Thank you both for your replying. I realise now l have looked around that I will need to up my budget. The Woosh Camino looks like a very good deal for the money. Are you likely to be getting any more of the higher capacity batteries?
What bike
OK, so I retired last year and I have been riding an old Ailen ebike for the last year or so. I now feel the time is right for a new bike but i have a budget of £1000 max. What do you advise, im 6' 2" tall and use the bike for leasure rides upto 30 miles or so mainly on country lanes and surfaced paths. I look forward to your suggestions.
Speed controller query
thanks, it will certainly be worth looking at the motor to see if it's faulty or mot.
I'm told that the gears in the motor are shot, it was worth asking about the compatibility just in case. Thanks for your quick reply.
I have been offered a second hand conversion kit which is complete but has a faulty motor. My question is, the faulty motor has hall sensors, I have a wheel but the motor doesn't have hall sensors can I use that motor?
Batteries in parallel
So is that a no?
When you say same basic chemistry, could you mix lithium ion and lithium polymer cells?
I was wondering if it's possible/advisable to run 2 battery packs in parallel to increase the range? As long as the batteries are the same voltage and similar capacity I don't see a problem. Look forward to your feedback.
Dash/controller
Thanks that's what i'm looking for.
Dash/controller
Hi, Can anyone recommend a controller and display panel for a non sensed hub motor which won't break the bank?
Power on/off
Sorry I don't think I made, myself clear what I want to do is if possible rig up some means of being able to ride without assistance on the level but have assistance on hills without stopping to use the battery switch. Is it possible to do this on an old system?
Power on/off
Hi, I have an old Alien bike which has basic controls, ie no digital display. I don't want to use power all the time but I can't switch on and off other than using the key on the battery. Is there a way to switch power on as required?
halfords staff complete retards!
My friend fitted a wireless one to his ebike and every time he used the motor it went haywire, when he fitted it to his wife's non electric bike it worked perfectly. I rest my case.
I tried to buy a wired bike computer from my local Halfords. I explained to the lad on the bike repair that I didn't want a wireless one as I thought the magnetic field from the hub motor might interfere with the signal to the head unit. He looked at me like I had gone mad and said " there's a always a magnet on the spokes and that doesn't cause a problem" is it me?
