urbanglide 140 e-bike +s866 controller
Your new battery is the same voltage as the original, so your tip speed should be near original, even with increased wattage. What speed does it read with the wheel spinning in the air?
LCD S866 + Brainpower controller
I honestly can't remember which of. My 3 wires is correct. All up there are only 6 combinations to try.
Id just try the pas wires in any combination then. One of mine when hooked up "correctly" by colour doesn't work. To work on mine 1 is correct by colour and the other 2 are opposite.
E7 is hall failure in the hub. There is no failure code for the actual motor.
Is the motor a known good motor? Disconnect the 3 big wires from motor and while shorting 2 of them together, try spin the wheel backwards, is it very hard to turn?
Hub motor power upgrade
This will run your motor at 13a. It can run 24-48v according to the specs however I think it actually goes up to 52v. It WILL need wiring in. 3 wires for throttle, 2 for power, 3 for PAS if you want that, 3 for motor and I think 5 for hall sensors. https://a.aliexpress.com/_mNadwnX
That unit looks to be epexy filled, makes it a pain to do a shunt mod. If it's 250w [mention=22943]36v[/mention], you should be able to get 336w out of it if run on a 48v battery, assuming it can run 48v. A far cheaper option would be an aftermarket controller. Running your current 36v battery at 13a would give you around 470w.
New vintage conversion
1st hurdle. The battery I got is from a Shimano Steps equipped bike. It turns out this batterys BMS communicates to the Shimano charger and the original bike in order to work. Without that communication the battery won't turn on. Looks like I'll be removing the Shimano BMS and fitting an aftermarket one.
Ya that's still in regular use. I think that's near 3000km on it now.
Yep the Yep the brakes will line (just) up with the new rims. A this stage I'd pref out of place looking rims to keeping the original rims, which are not straight, and mismatched anyway. Eventually I'd like a good set of original rims and lace the motor to one of them. Failing that, I may paint the alloys rims white.
I'm doing another vintage conversion. I scored another cheap Raleigh with pannier bag, and an electric conversion using a 700c wheel set. The only thing left to get is a controller. The battery is a 36v, which should be good for around 470w, with a cheap China controller. The only modifications required are a slight file of the dropouts. Build cost: Bike $75nz Motor/wheels/battery $300nz Controller $55nz Total: $430nz/$300us/£225uk
I've 2 of these controllers which are identical however they display differently. One will display wattage, but this is the one you DON'T want. The problem with it is that if it has a an error code displaying, ie e07, it will only display the current speed, and pas. You can't see trip, wattage, amps, odometer, or time riding. Basically it's stuck on the error code screen. This is a pain if you are using it on a motor workout hall sensors. With this one, if there is no fault codes, it won't have any error screen. The one that doesn't display wattage can still display all other screens if it has a fault code showing, when there are no fault codes, it will display e00 in one one of the screens when you cycle through all the displays. Also, there is no error if the main motor wires are disconnected, shorting or faulty. The e07 code (motor fault) is only related to the hall sensors.
Alternative to Ezee hub motor
Plug and play in that when it was wired in, it worked. Not plug and play in that the plugs were different so I had to wire it in.
I've got a an old eZee motor, and have used that motor on 2 different Brain Power speed controllers/lcds. Both were worked fine and gave it current control on pas and throttle. I was running it at 13amp, 36v so around 450w.
Spinnanz
Joined
Last visited
