tommyh7
  1. Hi all got a question that really confused got a 850c display that i thought was not working so i bypassed it with programing usb stick all working tried the 850c display on another bafang bike it is working can anyone help or am i missing something pic attached of the cable i used to bypass it
  2. just tested the throttle all good got to be the controller what do you think
  3. meant to say when it was working yesterday i noticed when i realised the throttle the wheel was still going not fast probably about 2 to 3 mph if that helps
  4. OK give a go Tomorrow i will get back to you Thanks
  5. Hi Nealh just one of those cheap ones pic attached tested the battery all good no display just press the button on the throttle all lights up full charged showing output 54volts no issue with the battery all ready tested it on another bike i thought might be throttle issue as that is the ignition key but all lights up as i said but when i switch of the battery as i said in my first post tested it next day motor was running then swithched it off again then on nothing i think might be the controller?
  6. Hi all got bike the other day with fault the back wheel spun out ripped the cables out manged to solder them back on all connected light turns on but no power to back wheel so switched the battery off came back the next day switched battery back on and it worked i said to my self great all working again switched it off put back on same issue not working has anyone came across this issue Thanks
  7. Hi Chris really appreciate been looking but no luck how much do i owe you
  8. Hi all looking for this missing part does anyone were i can buy reset button and start button for the Bosch intuvia
  9. OK got it thanks very much for your help
  10. so it would be better to keep it as 7 speed? and yes it was SRAM PG950 nine-speed 11/34T
  11. it is a freewheel this is the one i am thinking of buying
  12. Hi everyone just a quick question i have a 1000w hub motor wheel my bike is a giant trance x3 now at the moment it has a 7 speed freewheel on there but can only keep it in the second last gear my question is can i put a 9 speed freewheel on there as my bike is 9 speed before conversion
  13. Hi all i have fixed my bafang 1000w motor all it was nylon gear thanks for everyone's help but i have come across another issue the throttle keeps staying on what i mean is when i press the throttle down the motor kicks in then when i realis it goes back to the off position but the wheel keeps spinning and without turning the display off it keeps doing it any one have any ideas what this is thanks
  14. I heard the steel one is very load and thanks for confirming that it is BBSHD
  15. Hi all i found out what was the issue with my bafang 1000w mid drive it was the nylon gear when my friend took it apart he found out it was the nylon gear was stripped but i know there a different versions of bafang nylon gear can any one identify which one i have here is a picture
