Admin please delete or ignore this post.
I was deleting it to protect the seller, as it was a genuine mistake on their part that they amended. However if you want to re add the link as you have done then what can I do about it.
FYI. I actually edited the post before I saw the reply. VFR400 was probably replying at the time, as he does spend most of his time on here and was quick off the mark. I also did thank him for his reply none the less. Second. The post was about a business that I have now contacted and the issues described in the post was a genuine error on their part and they have amended their description and information. Therefore in the interest of fairness I cannot and will not allow what I published in the post to be shown. I believe I have the right to remove anything that I have typed in haste/error. Hope you all understand.
Thanks vfr400, but seller has sorted the info now. Motors are stamped 350w. They were apparently misinformed. I'll leave it at that.
Ladies ebike conversion and battery location
I currently have Woosh's fat bike kit on one of my bikes with the same battery, so once I find a suitable bike for her, I'll have a play about with placement. Cheers.
Thanks for that, this was what I originally had in mind, but I couldn't visualize it as google image search didn't seem to show anything appropriate. While it would be nice to have it lower for a lower centre of gravity, I guess it isn't really any higher than having it on a rear rack.
vfr400 is dead right, this type can and has damaged frames, if you do a search there's a few posts about it, sadly including mine. Dave. yeah it wasn't expensive, but mine doesn't have a lot of weight on it. Just carrying some bike tools, tube, repair kit, sun glasses, that sort of thing. Will probably replace it with a proper rear rack soon.
Good point. Guess I'm going to have to think about this a bit more and see exactly what she wants to get a better picture of best how to proceed. Maybe see if she can cope with a slightly higher top tube that is still low like my fat bike or accept a full rear rack that I can modify to accept the downtube battery? Cheers vfr400
mmmm? I wonder? I have a rear rack that has a 10kg max load and attaches to the seat post (it's on my fat bike). The rack is screwed to a long post, so the rack part can be removed leaving the horizontal post only. I could possibly mount the downtube battery to that with numerous rivnuts, although security may be an issue, as the post could be removed? Going to have to see what she wants I guess. I suppose she could do some leg stretches and ride a bike with a larger triangle frame?
Problem is she wants to tackle a steep hill to her house after shopping and wants a trailer as well, oh and basket!. It also has to be 250w legal, she's an ex cop...... So I'm looking at one of the 48v Woosh kits with downtube battery. Pretty limited given the requirements.
A female friend has asked me to build her an ebike. Problem is she wants a ladies bike with the deep step through. I don't want to mount the battery to a rear rack, as the kit I'm looking at comes with a tube mounted battery. Would putting it on the top tube be OK? I realise that that would take up step through space, but having looked at some ladies bikes would still give a reasonable amount of room if I mount it higher up on the frame (I think?). It may also make it easier for her to remove possibly? PS: battery has to be locked in and secure as she will be using it for going into town. Any suggestions or alternatives?
Need some shifter advice please
Hi, yeah I have those in my spares box, but as you say they don't work with Hydraulic brakes as they can not fit next to them due to the reservoir. I'm 95% sure that the ones I noted will work, just wanted conformation before I bought the shifter and cassette. Think I'll just do it anyway, as they're not expensive items.
So, got my fat ebike up and running great. However the previous owner fitted a 7 speed SRAM MRX Comp twist shifter. On the trails I'm riding I accidently change gear occasionally when riding over bumpy surfaces, so they have to go. The bike is fitted with hydraulic brakes, so will need something like the Shimano SL-M310 that fits underneath the brake lever. I believe this only comes as an 8 speed shifter though?. However I can replace the 7 speed cassette I have with an 8 speed cassette if needed. My question is will the SL-M310 be compatible with the Shimano Tourney derailleur I have. I believe the SRAM shifter has a 2:1 actuation, but I'm confused about what actuation the SL-M310 is as I'm finding conflicting compatibility information on the internet. Any other suggestions/advice for replacing the twist shifter also welcome.
Help and advice with cassette choice needed.
Hi Tony, just one question. My 26" fat bike wheel/tyre measures just a bit over 28" high, should I set the wheel size to something like 700c or keep it at 26". Will I have a more accurate speed reading either way?
UPDATE: finally got the cassette yesterday and the bike is now complete and I have to say I'm very happy so far and I couldn't be happier with the outcome. The 48v G06 motor is excellent and the bike pulls very hard and there's plenty of torque for even the steepest hill. Just a few notes for those with a fat bike and looking for a kit or looking for a fat bike to convert. Things I noticed when doing research on fat bikes is that they seem to have different width rear dropouts. Usually 170-180mm but can be as little as 150mm and as large as 190mm. What this means is that you will have make sure the kit is suitable for the bike you have. Mine wasn't too far out, but I did need to use a few spacers here and there to align the wheel properly and add 5mm shims to my brake disc caliper. A lot of fat bikes, and mountain bikes for that matter seem to have a steep top tube making fitting a tube battery difficult. Mine is just about OK, but drilling the holes for the extra rivnuts was tight. Finally, you may have to use a left pedal assist sensor if you don't have room for one on the chain side like I had to. Apart from that the rest of the fitting was straight forward. Can't wait to take it out on the trails (probably this Sunday). Highly recommend this kit. Here is an image of a cheap ebay controller box I used for hiding most of the excess cables:
MikeFB
Joined
Last visited
