mikeydread
  1. thanks again for the help. I have checked cables, unscrewed battery connector panel and all cables seem well connected. I'm not sure exactly what the 'motor connector' is? is that the cable that goes into the axle. Before all these checks the motor now no longer comes on at all.
  2. the battery indicator lights stay lit when I use the throttle or peddals..
  3. oh well...still having the same problem, actually much worse, motor only comes on very occasionally for a half second. The bike has a throttle which drives the motor independenlty from the pedals but this is the same so I am wondering if it is something else entirely than the magnetic disc on the pedals? I really don't know what else to look at, have checked all the cables seem ok and not loose.
  4. Thank you so much for the advice- I have had a tweak around and it was moving around. It seems to be working again now so its definitely something to do with that so whether I have fixed or not at least I know roughly what the problem is.
  5. Me too- I sent emails to this address. No reply yet. Guess they will have to answer the phone at some point.
  6. I am interested in the first one of these, Please quote reference 111359. Is it still available? How would I contact the seller (apologies if its obvious, I just cant see how!)
  7. Hi. I have been trying to get in touch with kudos Cycles for some support. I purchased a Kudos Secret bike last year and it has developed a fault where the motor is cutting in and out sporadically. I would like to know how I can get the issue diagnosed and fixed. There is just a 'no-ones here' message on phone number from the website. I am now worried that I won't be able to get support if there is no stock. Do you have spare parts if needed? What is the best way to contact support?
