gesanners
  1. I've answered my own question - the front chain ring is bike specific. Service parts can be obtained from Bristol - https://www.reallyusefulbikes.co.uk/
  2. Hi, I have a 2012 Agattu C8 Impulse which needs new front/rear sprockets and chain. Are these specialist heavy duty parts or is there an after market option? There are a number of ebike shops around the West Midlands, has anyone got a recommendation re where to take it? Thanks. Gerry.
  3. My 2012 Agattu powerpack was supposed to be good for 1000+ charges. In reality I charged the battery no more than twice a week over a 3 year period. 150 weeks x 2 charges = 300. I haven't even allowed for 6 weeks a year when the bike was little used or not used at all as I was on holiday. The battery has become very unreliable and cuts out completely after a short distance. After much deliberation I've bought a new battery. My options (from 50 cycles) were - 17ah - £795 15ah - £595 11ah - £395 I went to ebay and Amazon, did some research and found a company called Telstar in Germany who provide a 13ah battery for £310 including delivery. This is the largest capacity battery they sell.Mine arrived within 3 days. 50 cycles don't sell a 13 ah battery, if the did it would cost £495 based on the above. I've been out for a 10 mile ride today and all was well. I'll update my findings in a few weeks, I hope the information might prove useful to someone else in a similar predicament. Gerry.
  4. Hi Reggie, I have a similar problem with my 2012 Agattu. In my case the battery is probably nearing the end of its useful life. I've just spoken to an electric bike shop in the Midlands to ask about a battery refurb and in the course of conversation discovered that there is something called a battery management system within the battery. This deals with the distribution of power from the charger to the multiple small batteries within what you and I know as 'the battery' If one of these small batteries fails, the management system will shut the battery down. You may well have a duff battery. Gerry.
  5. Hi, has anyone committed to a refurb of their original battery? I think mine (Kalkhoff) is giving up after 4 years use and I see there are a couple of outfits advertising battery refurb on ebay. My initial reaction is to doubt the likelihood of success but there may be someone out there who can offer advise please? Gerry.
  6. All was well until 2 days ago when I found that there is no power to the on/off/pedal assist indicator and of course no power to the bike itself. My bike is about 3 years old. The battery charges up and holds a charge100%. Has anyone else experienced a similar problem? Gerry
  7. Thankyou all for your replies, it's great to be able to share knowledge and experiences. In my case I have the Impulse motor and I'm delighted to say that theproblem eminated from worn pedal bearings rather than anything more sinister. If you haven't done so, try buying a decent set of pedals!
  8. Hi, thanks for your reply, the chain rests very close to the base of the battery however in use it tensions and that isn't causing the noise. i've removed the chainguard and the noise is still there unfortunately.
  9. Hi, My Agattu is about 18 months old and covers about 40 miles a week so has done around 3,000 miles total. The bike has just developed a very annoying ticking/clicking noise from the front sprocket which is of course also the location of the motor. There is no play in the sprocket or pedals. i've just had the front sprocket and chain replaced and this has made no difference to the problem. The noise sounds very similar to that you get when a bottom bracket is on the way out. I'm getting concerned because I understand the Kalkhoff Agattu has no bottom bracket as the bearings are needle bearings which don't wear. I'm taking this up with the supplier but I'd like to hear from anyone who has knowledge of the problem please. Gerry.
  10. Hi, My Kalkhoff is about 30 months old and has covered approx. 2,000 miles. Recently I've experienced a very noisy bottom bracket. It's making a very annoying and loud 'ticking' and 'clicking' noise which from previous experience with a Wisper pedelec precedes the bracket bearings packing up. At first the noise was only evident under load but now it's constant. I don't need to use my bell anymore! I've changed the front sprocket and the chain and the noise now is even worse! I've spoken to 50cycles who told me that the bottom bracket is not a replaceable part, that the bottom bracket has needle bearings and these don't wear. Now I'm getting worried! Has anyone else had a similar experience? Gerry.
  11. Many thanks flecc, I'll take a look at that. Gerry.
  12. Hi, I've just bought the Aggatu to replace my Wisper 905se. I'm very happy with it - it's good to have some brakes that actually work! I do however have an issue with the front wheel/steering head and I wonder if this is peculiar to my bike or if anyone else has had it. Imagine cycling on a smooth tarmac surface with little air in your front tyre. When you turn the handlebars slightly the bike snatches in that direction and then in the opposite direction when you try to correct it. It's an odd feeling and I can't explain why it's happening. I've replaced the standard tyres with Marathon Plus but surely they wouldn't account for this? If you have a similar bike I'd appreciate your help. Thanks. Gerry.
