projem
  1. I am looking for a large MTB 29er/700c non suspension bike frame that can accomodate the BBS02 motor that allows wider tyres at the rear. I am NOT looking for a fat bike but a sturdy hard tail frame that will take a 2.5" tyre or less rear wheel without breaking the bank. New or used. Thanks for any advice/help. I am 6 foot and 224 pounds/101 kilos/16 stone. Thanks in advance, Jem.
  2. Scotty, do all these companies supply disc options on a 26" wheel? I'm thinking of going 26" in my 29er forks.... its only a matter of time before I crack this 29er frame
  3. dont get the video though - but could be me
  4. Hi Alan, my ball park was £600 but yep a K was not out of sight.... if it means a bit of pedalling but saving a bundle... hmmm, thanks for the reply, J.
  5. Hope someone can help, I am looking for a front mounted hub motor with disc mount, either 26" or 29er (no legal restrictions and unassisted if need be, looking for torque up to 25mph), controller/battery and thumb control. Need to cover 20 miles daily on our site 365 so reliability and a UK supplier/support would be appreciated but not a deal breaker... handy with solder if need be on seperate components. Thanks for any suggestions, J. ps mounted in a Surly Karate Monkey 29er steel front fork with disc mounts
  6. Sadly I have four of the 21 LED front light and all stopped working for various reasons, but all down to poor quality. Clicky switch on rear is poor, all leds badly soldered to connections etc and cant be swapped to another as spares. Unless you want a cheap light for a couple of months, who knows if they ever get wet (mine didnt).
  7. Wraggy Did you save any scans of manuals etc.
  8. Wraggy, any info as I also now own a Mercedes Electric Bike.... any scans of manuals available? Thanks.
  9. Charger to battery box connector Thanks flecc regarding motor maintenance.. I need to get the other end of this connector to glue within the battery box, can anyone tell what there called as "3 pin standard connector" brings up many when Googled. Can anyone recommend better connectors for both ends that may be suited to a flush battery box surface with waterproofing in mind, thanks.
  10. Injecting 24v Thanks flecc, didnt want to buy a battery pack and charger only to find the motor defunct.... should a low mileage motor, left in a dry environment, deteriate over 10 years? There seems alot of belts spinning etc . Anything I should do/grease/clean before injecting 24v after such a time? Thanks
  11. I bought one too, based on posts, so as to not need to fiddle with rear hub motor..... not fitted as yet. Mines a Tour...is it the same?
  12. Testing motor with less volts? Would it be possible to use one 12 volt battery, just to see if it spins, could this damage the motor using less volts? Thanks
  13. Thanks flecc Is there an easy way to check the motor and batteries before spending money on a new battery pack and charger?, Im assuming/guessing the Ni-Cads are defunct after 10 years despite 1 or 2 charges, but cant tell without a charger to test both. Thanks for any replies.
  14. Thanks Bob Thanks for the explanation Bob and for posting the pictures.
