mimran91
  1. did you install it in the end? Im only asking because I am considering the hyb 8.9 as a donor bike for the tsdz2
  2. Is this on the tongsheng? If so which throttle as I have read some throttles only provide a limited response
  3. I want to have OSF. I had no idea about the diff controllers and thought I NEEDED to buy the newer one so will be going to PSPOWER
  4. I was going to buy from pspower until I saw your post. What is the difference between the controllers?
  5. Thanks for your reply. Will there be a spare cable to attach the gear sensor to? Or will I need to replace one of the existing sensors with it?
  6. Im buying a BBS02B kit from ebay and want to know if they include a gear sensor or if I will need to buy it separately? The listings all have a brake sensor (or brake lever) included as well as a speed sensor but none say anything about a gear sensor specifically. I am therefore assuming I will need to buy it separately? Here is the kit I am considering: https://www.ebay.co.uk/itm/394220721290?var=662734918518
