Pharmhand
  1. I have a half twist throttle on an e-bike conversation with a Kt controller and a Kt lcd3 display. When I twist the throttle it goes from no power to full power with out the ability to give partial power. Is there a setting on the controller that can change this or are there different types of throttles that allow gradual increase in power?
  2. Thanks for the quick response. Here are pictures showing the motor number and also the controller
  3. I tried these settings and it works except the speed display is off (It reads 2mph when I am going 12mph) also there is a delay in the pedal assist kicking in until I reach a certain speed. I would appreciate any suggestions Thanks
  4. I have a swytch generation 2 kit (wheel hub AKM 100sx 6xx 36hb) I want to program a Kt controller with a Kt Lcd3 display to work with this motor. I am trying to get a couple of settings . P1=motor gear reduction ratio × number of rotor magnet pieces And p2 is the wheel speed pulse setting. If you have programmed this type of setup can you give these settings? Thanks
