Morrisgj
  1. I have Yose 350w conversion kit on my bike with the C500 display. I have read that it is possible to configure the PAS levels to specific power percentages and increase the number of levels to 9. These settings are not accessible on my display. Does anybody know how to get to them or can I replace the display with another type that allows access to these parameters.
  2. Can anyone tell me the right P & C settings to get a KTD12L PAS sensor talking to a KT LCD5 display and a KT15 controller. Will it work if a thumb throttle is also plugged in.
  3. Can anyone tell me the setting to get a KTD12L PAS sensor talking to a KT LCD5 display and a KT15 controller.
  4. Can anyone tell me what the P1 setting in a K-lcd5 display should be for a Mahle x35 motor. The P1 is derived from the motor gear reduction ratio x number of rotor magnet pieces.
  5. Would you be able to recommend a suitable controller and display model. It’s a 250 watt motor, 36v.
  6. Thank you. I am new to all this. Will the KT controller work with only battery, motor, pas and display connected.
  7. does anyone know if a KT controller will work with a Mahle x35 hub motor? The motor has the 9 pin connector.
