Tuesday at 17:424 days I have Yose 350w conversion kit on my bike with the C500 display. I have read that it is possible to configure the PAS levels to specific power percentages and increase the number of levels to 9.These settings are not accessible on my display. Does anybody know how to get to them or can I replace the display with another type that allows access to these parameters.
Tuesday at 23:464 days https://cdn.shopify.com/s/files/1/0378/5506/8295/files/C500_manual.pdf?v=1679586295If your display wont provide access to the settings you require check with yose support you have the correct controller/display.my own 250w kit is supplied with hobbled f/w that prevents setting anything beyond display metrics, but iirc member @cadence has both 250w yose and 350w kits installed on bikes and has confirmed his 350 controller/display combo on the 350w installation IS NOT Hobbled in the same fashion as the 250w kit display.
