Gogo best gf700 strangely shut down
Brilliant thank you so much will check tommorow morning
San eagle would you be able to tell em what else to check for before buying these new controllers and then it still don't work like how to check if the throttle works and the motor for instance while I've still got this multimeter I've borrowed
The defective one is the smaller one with less wires which I think is for the front wheel. The other controller with all the extra wires is for the rear wheel from what I've read but I tried plugging that in and trying it but no response from throttle or anything which has left me puzzled
Red probe along track at top circled in red with black probe on red , green , and blue separately It says between 7.62k and 7.71k through the 3 wires at separate tests Red probe to lower track circled in blue I get 0.L on all three tests
It's the lower one in photo 51 am I testing the wrong track ? Il check the top now to confirm
I've just placed PCB on some paper and tested making sure my fingers weren't touching and now getting 0.L
Don't quote me on this but I read on a few various sites online that if it's showing less than 8k then it's damaged is this correct ?
My fingers could of been touching yes, very fiddly to do haha. Il put it on a worktop surface when home and do it again and also what you asked me to do and will take photos to be sure.
Theese are the result I got with the units on the controller 1. Red probe to red battery and black to blue it came up as 9.24 m To yellow was 9.28m Green was 9.33m Red probe to black on battery connector Blue 7.62k Yellow 7.71k Green 7.64 k Controller 2 has 7.62k on all 6 tests
The controllers were from the manufacturers website for This model and looks identical so I'd hope so. Okay sorry I'm a plumber I'm totally rubbish with electrics haha water and electrics don't go well together. When I watched a video earlier on the MOSFETs it stated what was what but I have no clue how to do it as it don't show on the PCb which is which. The MOSFETs are all 3 pin is there a specific way to test these, once again thank you so much for your help
The lower track starts off at at 13.5 far left the middle of track and ends up to 25.7 far end. If I was just to buy the replacement controllers as this is getting abit technical for me and I don't really know what I'm doing haha, would it just be a case of plug and play and it be back to normal or is there more to it ? Also being the tech wizard you are could you tell me how to check my throttle on multimeter to confirm it works okay for peace of mind. Thank you so much for your time and patience it's very well appreciated
Sorry to sound stupid when you say track so you mean the pins on each MOSFET or do you mean the long silver bar of solder ?
Now while checking again is constantly dropping right down again ? New controllers needed ?
Now I have 5.2 ohms on all 3 colours with red probe on red wire, yesterday I couldn't get a reading atall, very strange
Hurcombe676
Joined
Last visited
