Sonar.sonar
  1. An up date ordered a new light from the Fido website. No mention about no stock but now it seems no stock there awaiting a delivery. begs the question now how on earth do they sell any M1 Pro bikes if they are awaiting a light .. thinking maybe a battery light will be better. As they cant even say when there going to be in stock
  2. I am not well known in the area and very very seldom go to town usually in the car . but for a change a ride about. Decided just to pop in for a tin of fizzy drink came out it it was damaged . just ordered a new lamp from Fido. they tell me its 7 to 8 days after receiving the order before they dispatch Then up to 21 days to get here . then saw this on EBay. the very same light same spec same make cheaper and 2 to 3 days delivery . hows that work .
  3. It’s a large bike and has a cage on the back as well .. it was a small shop ..
  4. Ok now wired back up everything works except the light. Even the horn works. So ordering one today. Shame as you can't just get the bulb on the board you have to get the full light
  5. Thankyou i have just asked now how long the delivery will take ..
  6. the front light was smashed while it was unattended . now nothing works so it was chained to a bike rack just while u nipped into a shop i came out and the front light has been smashed and the wire to the throttle has also been cut . now i have nothing at all so is there another front light i can replace this one with and how would i wire up the three wires any help would be greatful this is a Fido M1 Pro 2004
  7. I use engine oil and have no problems chain run through a oily sponge then run through a clean cloth . done this way back in the early 70s
  8. There is no password to lock the speed. And removing the throttle means it’s harder to peddle above the 15.5 mph. You can set the speedometer to not go above 15.5 . there is no stamp on my motor at all just a sticker
  9. It has a throttle but it’s disconnected still there but does not work the motor has a 250watt sticker but no other markings .
  10. Here’s an image of mine. Or is it .? I know what it is and how it’s been made now into a legal uk bike Sometimes ….
  11. Are all Trioblade e-bikes use the same 250 watt motors. even though they are cheap seems they are still not uk road legal because of the throttle speed. disabling the throttle will that then be a uk legal bike .
  12. Mine is emphysema thats a lung problem most people would just sit in a chair and do nothing . i am stage 4 I do what I can and do not rely on others if possible . i peddle when I can and throttle when I need a breather . stability is no problem I used to kayak but never kept up with the others . And knew when it was time to stop kayaking . riding my bike gets me out to the local beach for fishing a disability scooter would not go across any rough ground . the beach is only 1 1/4 miles away and only cross a road the rest is waste land and cycle tracks .
  13. Snap I am in the same condition also in the northeast and thinking the same with the throttle acute severe emphysema that’s stage four so peddling or ghost peddling is ok . but not sure I could just peddle especially pulling away . this is a freedom thing for me aged 70 .
  14. It was 500W but now it’s a 250W. that’s what the sticker says there are no details inside the motor but lightly marked of the wheel motor casing removable plate. easy fix and it’s all Matt black spray paint . its the throttle I think the problems going to be. peddled up speed is 15.5 mph no more. so without a throttle and when it’s removed it should be road legal and , adheres to the EAPC regulations. I hope unless someone can Say more .
  15. Peddling the bike does 15.5. But so does the throttle. so I am going to disconnect the throttle hence the throttle will not work but peddling at 15.5 is ok seems this is legal as peddle assist and no throttle. as I can peddle 15.5 mph. But if I reset the speed by unlocking when I peddle again will this be reflected in speed or does the peddling speed stay the same at 15.5 mph.
