DavidG1981
  1. I recently bought a Windgoo B20 I am looking for a replacement battery However, eBay has been notified to remove all listings regarding the bike as it can cause a fire risk So looking for a replacement battery is difficult Any advice would be appreciated
  2. Thanks The batteries have been tested and are fine, they were brand new when I bought this second hand in June last year, I frequently use so I don't think the batteries could have soured just now My friend did try testing the charger previously but could not determine back then, his voltage meter was playing up, I suspected a while ago the charger was suspect we would intermittently go from green to no light This is the connector for the charger I wonder if I could source a similar charger for a mobility scooter which would work just as well
  3. It's definitely the charger as no light comes on when attempting a charge, having an investigation one of the capacitors was loose, so a friend tried to resolder, but this has not fixed the problem, I have also tried charging without plugged into the bike and the same problem The bike itself takes 3 times 12V lead acid batteries
  4. I have a vintage electric bike, Sakura Shopper,. either s305/s307 It has a throttle This bike is from 2002, had one careful owner than it was sold to me The charger no longer works The problem is sourcing a replacement, as Sakura went out of business in 2007, the shops which was bought from Fleetwood cycles ceased trading after 40 years also Even repair shops won't repair anything smaller than a fridge, over, washer, dryer etc So I am unable to use the bike Any advice would be appreciated
