johnamon
  1. Thank you d8veh, if you find somethine of use then I can always order heavy spokes with my other BMSBattery items (brake levers, torque arms etc), I've never had shipping from bmsbattery without a motor in rim - hopefully the price is more sensible...
  2. Sorry for the delay d8veh, I skim read while at work and missed the question.. Either would be ok but laced into a 26" wheel would be more conventient
  3. Thanks cwah, I am looking for a slightly slower wind as I'm hoping to make a slow moped for my commute and so don't plan to pedal... My 345wind BPM doesn't like starting from a stop much at all so I thought I'd drop the top speed some. Thanks though
  4. Sorry i missed those important points d8veh, I'd like a rear drive 500w. I've been concentrating so much on the wind and voltage/power requirements that I forgot the basics - like which end the motor is going on!
  5. Hi All, As the title states I was hoping to find a Bafang BPM2 36V @ ~250RPM winding that someone might have spare. If nothing crops up then i'll just have to stump up for the shipping from China! Thanks, John
  6. I ordered a couple of these and run a 3x cree XML beast from 1 of them Stepdown Converter Please note that the heatsinks get warm, and I therefore think these units will last longer than the lyen ones which appear to use the same chip without heatsinks (please correct me if I'm wrong)
  7. ha ha, as Old_Dave said - LIPO is much more fun! But in order to benefit most you will need a new controller - or to reprogram your old one. Also a 250W motor may not draw enough power to make the most of the expensive batteries that you are ordering. My 350W 8fun BPM motor is much improved, but I'm not anywhere near moped territory because the motor simply doesn't have enough copper inside to draw the amps. Just depends what you want, but lipo's won't entirely remove the need to pedel!
  8. I also have an icecube57 built harness. It wasn't cheap - I asked for a harness to to allow 18s3p to allow me to run my 6 lipo bricks in either 18s2p or 12s3p - a lot of connections meant an expensive harness, but the job is neater than I would have managed. This winter I upgraded to lipo, I needed new HK lipos, a DIY meanwell bulk charger, some cheap chinese lipo balancers, a wiring harness, a new (lyen) controller to allow / handle all the current and a new pannier to store the batteries. I've spent nearly £500 in total including shipping and getting really lucky with no customs surprises. Please don't tell my better half the total.. LOL p.s. Please remember that you'll need a power supply to run the battery charger - they don't tend to work off mains voltage (PITA)
  9. Last year I went go-karting during the Christmas holidays. My hands felt completley frozen after the first race when just wearing the standard fire safe gloves that the kart centre issue you. The staff suggested that for the next race I try latex / plastic surgical style gloves underneath - wow what a difference it made! When the weather gets cold I'm just going to get some cheap surgical gloves and wear them underneath my usual cycling gloves - they act as a wind break. Everything is still thin, so you don't lose dexterity.
  10. I shouldn't worry too much about the delays with BMSbattery. They took two or three weeks to produce my battery - apparently they order them in individually and then they run a few charge / discharge cycles through the battery to try and accertain that the cells inside are all good before the ship it. Although it took about 3 weeks to leave the workshop in china, I had it delivered within 36hrs from the otherside of the world. I knew to expect a delay but I am delighted with the goods.
  11. I have found the runkeeper app to be as accurate as I need, particularly when at 20mph ;-) If fact reviewing any of my cycles (logged on an iphone) shows sufficient accuracy to see where I have followed the contours of small roundabouts! http://runkeeper.com/user/johnamon/activity/49811213
  12. I record most of my cycles via this app. It's web interface is great for showing friends & family routes that you have cycled. John Amon, Aberdeen, UK | RunKeeper
  13. I won't be satisfied until I'm running a Mr Fusion ;-) http://fastcache.gawkerassets.com/assets/images/4/2007/12/medium_Mr_Fusion.jpg P.S. The foreign oil bit isn't a political statement, I just thought it added to the joke when I found it on google image search.....
  14. Thanks Frank, After the heatshrink I'm going to pack out the connections in blu-tack - wrap the blu-tack covered connections with a piece of old tyre and cable tie the gunged arrangement closed. I hope the connections don't get too warm for the Blu-Tack, we'll have to see how it goes!! Thanks John
  15. Hi all, This is my first post here - apologies for how daft this question may be!! I have just installed a BMSBattery kit to a nice and light 1990's specialized hardrock. Despite no instructions being included, with a bit of help from the guys at BMS I got the kit installed in less than 7hrs. This is my first experience of an electric bicycle and it is fantastic! Although the kit is installed sufficiently to allow me to ride in the dry it is not waterproofed yet. Because you receive a box of (very reasonably priced!) bits from BMSBattery, one must extend the battery, motor and pedelec wires mid-line. Can anyone tell me from experience if Blu Tak is stable over time and water repellant (rather than dissolving or de-naturing over time!). I've had a crazy plan to pack out the joins in my cables with blu tak, then wrapping the blu tak packing in tape. This would seem to be a more reversible waterproofing solution than packing out with silicon sealant.... Thanks all. John
