bafang midrive problem display and power cut
it cuts out randomly even when not moving , to power back on i have to disconnect switch from display unit and then it powers back up, i'm thinking maybe a faulty switch ?
hi all , have a problem with my bafang kit the display keeps cutting off and won't come back on again unless i unplug it checked all connections all good any suggestions ?
middrive motor quick release wheel
ok thanks guys
hi wonder if anyone has a midrive fitted with a quick release wheel at the rear want to travel with bike next week and want to swap out bolt on wheel with Qr so i can remove easy for train not sure about strength of quick release v bolt on with midrive have the Bafang 500w kit fitted so quite a bit of torque any info appreciated
folding moutain bike
ok thanks I'll email order
Ok thanks sounds good ,the weight of the battery means i could carry it easy in a pannier I can order the bike but i can't see the battery listed in your online shop how do i go about ordering this?
the easy solution would be to buy an additional battery with the bike so i could just swap over , do you have batteries additional batteries to buy?
- folding moutain bike
I was looking at this bike and would had bought it the only drawback for me was the battery i want a greater range, i have 3 batteries which are which are 20-21aH I bought a couple of mid-drives and a big bear kit from you last year and was hoping to unitize one of those . Is the battery on this bike removable?- folding moutain bike
i was thinking of rack mounting it or maybe if room mounting it on the crossbar a have a 21ah dolphin battery that jimmy made for me , although the one he has made for your bike looks nice and compact in that bag- folding moutain bike
Hi all wondering if anyone has had any experience converting a folding mountain bike using a Bafang mid drive motor kit ,looking at building one to take touring around Cornwall any info/advise appreciated- Bafang kit problem
the battery pack is 36v ,the full charge voltage is 38,2 v and in my opinion this is wrong in full discharge state voltage is 32.4v peaks amps drawn during test was 19-20amps the battery pack consists of Ncm pouch packs which are normally used in the electric car industry- Bafang kit problem
hi all I'm wondering if anyone has experienced the problem I'm having with my Bafang bbs02 kit ,i fitted this kit a few weeks ago and have been using it along with my Ping 36v 15ah lifepo4 batteries with no problems at all as these batteries are coming towards the end of there service life (4 years old)i decided to have a new bigger battery built which was a 17.5Ah Ncm pack when using it with the kit after about 4 miles with mid assist level the power level noticeably drops and the battery fully discharges after 6 miles, after sending the battery back twice the battery builder thinks the problem is with the kit as the cut off voltage is set at 31v on their controller as they are set up to use lifepo4 batteries therefore prematurely cutting the battery off .having carried out numerous tests all point to the battery fully discharging and not being cut off by the controller even using with a lower power kit with voltage cut off @ 27.5 v . i have never come across this and have always used bagang kits with different battery chemistries with no such problems has anyone experienced similar? any information appreciated- Bafang central motor kit
ok great thanks - folding moutain bike
Back to top
