Capn_Phil68
  1. I agree with Fishingpaul and if I see a cycle lane then I often take a detour to back streets (nearly always a way through) in order to put distance between me, my bike and lorries, cars, buses etc. There are exceptions to this though as cycle paths purposely designed to put real space between drivers and cyclists are great e.g. through green spaces. Bit of a cheat, but I have been weighing up buying a kiddie trailer as a visual deterrent to mad drivers as I've noticed that I always gave them a wide berth when driving (also read it in the theory of big). Think that it's quite important to take a pragmatic approach to road safety adopting a purposeful riding style with the aim of communicating a message of "Yes, I'm a road user too. Respect me and I'll respect you.", but when given the option simply go down the route less traveled. It's nearly always nicer, cleaner, more interesting and with far less Mad Max moments .
  2. Hi Wizard, That's my bike and the understanding I have is that 250w is the legal continuous output, but this means that the motor may peak much higher under demanding situations. It seems to me that the voltage = engine size and amps = fuel tank capacity. Hope that makes some sense as I am kinda getting lost and prob need an intro to electric vehicle science to clear my understanding. Think my bike would be more efficient if it was lighter, but the rub is that if it was lighter I wouldn't like to leave it anywhere as it would be stolen like my last few push bikes. ps hope the batteries work out and will defo go to the same supplier if they work out for you when my power pack gives up the ghost.
  3. Hi a415, Maybe try mr-motorvator but I think you may need an electric moped/ scooter rather than a peddle assist bicycle as these are designed as an electric powered form of transport rather than electrically assisted. Still in my early days of pedal assisted cycling and the power assist came as a bit of a shock as was used to motor bikes and was, initially, disappointed by the amount of power from the motor. I am now in the frame of mind that I have a peddled bicycle that has a bit of an electric boost for the exhausting bits rather than I have an electric motorcycle that I can assist if need be. Steep learning curve for me!
  4. .............................
  5. Yep, much prefer it as doesn't slow the bike down with cut off's. Went down a longish slope on Sun and got 22mph. I have an idea that battery life/range will be better as the pedelec function almost always seemed to be on. Time will tell :-)
  6. Hi Wizard, Good luck and please keep me up to date on the batteries. Sounds like a good deal as I suspect our original batteries may not have been deep cycle.
  7. Hi All, Have a quick read of the 'Theory of big' regarding cyclists and visibility. The theory of BIG I wear predominantly dark bike clothing, but use panniers to increase bike size, a bar end mirror, good bright lights and big jackets to increase my road presence.
  8. Check it out... Electric bike 48V USPD Home Conversion to 1.4KW 32MPH!! ps dont try this at home!
  9. Hi Tony, Excellent. try googling piaggio mp3 for a moped version.
  10. No and thanks for the link :-) What an elegant solution and think that is the way to go with maybe a smaller wheel. could also fabricate a rear rack for extra carrying capability. Yep, low slung batteries on either side. I LOVE this. I have a new form of personal transport and a hobby thrown in to boot!
  11. Hi Flecc, Lol, yep that's the one!
  12. Hi Wizard, Got a dose of cold at the mo so not biking for a day or so to the best of my recollection (did several tries)it was a small black three wired push on connector and wires were black, red and yellow. I checked by throttle by using the kick stand as a 'third wheel' and pulling the bike towards me so as the rear wheel was off the ground and then checked by engaging the throttle and there was no signs of limitation e.g motor cut out. dont think it will make a huge diff to speed maybe a few mph,but will stop the annoying cut off. See how it goes and I may change the smallest rear cog to smaller to increase top speed.
  13. Capn_Phil68 replied to a post in a topic in Electric Bike General Discussion
    Damn! We missed the obvious. Helium under pressure is contained in big heavy containers. End of. Anyway, back to the drawing board.
  14. Woohoo! my lil, fat, bike is now derestricted. Was a trial and error thing with unplugging connections and seeing what happened and plugging them back in again. Mods are almost coming to an end, with only the pannier rack to be fitted to modified mountings. Tho think that my bikes batteries are not up-to-speed re: range I require, but this will be checked in throttle mode rather than peddle assist as I feel pa is sometimes not required, but kicks in anyway. Musing about building a small unicycle, close linked (9") trailer to house batteries. All in all, great fun :-)
  15. Capn_Phil68 replied to a post in a topic in Electric Bike General Discussion
    Hell !!!!! I was only thinking the same thing last night re tyres and maybe helium cushions under/ around batteries. have a feeling we may be missing something tho. My excuse is the day we did science at my school I was off with a cold :-)
