8fun conversion kit
Thanks Amigafan, I'll give it a go.
8fun conversion kit
I hope they are, I'm about t o buy a new one but I don't use my E bike very often nowadays. The problem with the Throttle is the spring looks like it is broken inside I can still use it but the throttle is not returning to the original position. I might have to open it up and have a look.
8fun conversion kit
I had the same problem last year, they replaced my Battery. Last week my Thumb Throttle stopped working and e mailed them twice - no response and the phone just keeps ringing.
Loud lipo alarm
Mine is really loud, makes people look for a reversing Lorry! I'm thinking of disconnecting one of the speakers. G
Wobbly Front Wheel under braking
I have checked the spokes last night ant they are a bit loose but I don't want to tighten them in case I mess it up completely. I might take it to my LBS on Saturday. Cheers, Gerry
This is a good point, I wonder if I have rotor/pads mismatch. I used the bike for approx 50 miles before conversion . I wii tighten the spokes first before going for new pads. Cheers, Gerry
IMAX b6 lipro balance charger
Aha! This explained my reduced range and alarm going off. Thanks Dave Cheers, Gerry
Thanks Kirstin. I'll give that a go.
Hi Flecc, I'm considering buying a rear hub because of the weight at front plus the increase torque on the fork. I will do some testing atthe weekend. Installt he original wheel with the 180mm rotor and see if Istill get this issue. Can loose spokes cause this? G
Hi D8veh, This is a brand new bike but I'll check just in case they put in a dodgy headset but there is no play when I did the backward and forward test.
Hi Kirstin, The rotor seems fine and there is no play in the Headset. This is a brand new bike and since conversion I have always have this issue but a bit more worrying now with my Booster pack :-) The fork moves backwards and forward under braking as if the caliper is grabbing the rotor on and off, its a shame I cant install the original rotor as the rotor Im using is not Avid but a generic 180mm I can't even remember the name but it seems good quality. Cheers, Gerry
Hi, I have converted my Pinnacle Lithium 6 using an 8Fun Kit. This bike has Hydraulic disc with 180mm rotor and the wheel wobble under braking. I can see the fork vibrating backward and forward. I have checked the wheel for trueness and it seems fine. I have also checked the rotor bolts and the caliper bolts. Im getting a little worried that the fork might fail. The Fork is a Cromo with no suspension. I have never experience this before conversion. The original bike had a 160mm rotor but I had to replace to 180mm to accomodate the motor using a 180mm adaptor post. Any ideas what might cause this? Many Thanks, Gerry
Reviving a Dead Battery
Great Post, thanks for sharing.
This is interesting, I too have an imax b6 ac. I thought my pack is fully charged when it beeps at 120mins. I have ,I beleive, is 11V 15AH (3 11V laptop batts in parallel) do I charge this 3 times? I'm charging at 2.5 amps.
Booster Battery experiment
Back to top
