Swedish newbie, first build
The snow is gone and it's time take a look at my bike. Just sold the “Kudos Sport” I had last year, two IMAX B6 chargers and some LiPo’s. For my other bike with yhe XOFO I’ll probably use 2x(3x4S) Hardcase LiPo again or can I find a better alternative near that price? Any suggestions what equipment to use to charge all six, 4S at the same time? Is this bag a good choice to have the batteries in? 16" x 17" x 11" x 2.4" http://www.amazon.com/Ibera-Bicycle-Triangle-Frame-Large/dp/B006JA8WEG
Yes, but with no load (wheel in the air) the display shows 54 km/h (33.5 mph). That's a big difference, or?
Just tried the kit with 12S (cold and dark with no light on the bike). The display showed 41-42 km/h (26 mph) no pedal as I had no chain. [ATTACH]7162.vB[/ATTACH][ATTACH]7163.vB[/ATTACH] About 50 V and probably 20A --> 1 kW. If that's the case I'm a little disappointed. About 800W on the wheel or? According to this site 500W should be enough to reach 26 mph. http://www.commuterbooster.com/performance
Connected everything today with 8S. The display show almost 36 km/h (700c, no load) --> ~53 km/h with 12S (33 mph)?! [ATTACH]7028.vB[/ATTACH][ATTACH]7029.vB[/ATTACH]
Received two packages today. Everything looks good (I think...). I did expect a slightly wider rim (it's 622x16). [ATTACH]7015.vB[/ATTACH][ATTACH]7016.vB[/ATTACH][ATTACH]7017.vB[/ATTACH][ATTACH]7018.vB[/ATTACH] Hmm, I don't think the wheel is laced the right way.
Cheapest gents bosch centre drive bike?
Todays offer (400Wh, £1,389): Cube EPO Travel Pro black 'n white I think both Radon and Cube are high quality bikes. Three friends of mine recently bought Cube 29"ers from Bike-discount and are all very satisfied.
If it had the 400 Wh battery and the new 2014 Bosch it would probably be a lot more expensive... And I already started a tread about the new Cube hybrid. http://www.pedelecs.co.uk/forum/electric-bicycles/15644-cube-hybrid-2014-a.html
Radon Hybrid Nexus £1,212 Radon Hybrid Nexus
¨ "We have speed sensor inside the motor. Colin "
Cube hybrid 2014
I like them. The Reaction Hybrid Pro 29 seems to be the cheapest £1737 (in Germany). [ATTACH]6786.vB[/ATTACH] Cube Reaction Hybrid Pro 29 black´n´white´n´red All Cube hybrid 2014:CUBE HYBRID PS I like the new KTM also...
Got an invoice, but I want 700c wheels (did look again and it says 28" under "model", so probably right) and half twist throttle (or?). Will try to change before I confirm the order. Should I add something? d8veh: Did you read my old post before I deleted it? Will ask about the wheel-speed sensor also. [ATTACH]6782.vB[/ATTACH]
Great! Will probably hit the order button soon. Batteries: I have 6 pieces of "Turnigy 5000mAh 4S1P 14.8v 20C hardcase pack". http://http://www.hobbyking.com/hobbyking/store/__15521__Turnigy_5000mAh_4S1P_14_8v_20C_hardcase_pack.html Hope that will be ok to evaluate the kit.
15 x 260/201 x 48/40 x 28/ 26=25 mph If the cst 270 rpm gives 42 km/h with 12S (26") (your first post) the Xofo 260 should do about the same. I'm happy with 25(+) mph.
Thanks d8veh. 48/36=1.333 -->23x1.33=30 mph no load, or?
Found this at Endless-sphere. Endless-sphere.com • View topic - Torque-Sensor Motor w/ Sine-Wave Controller Build "I am disappointed with the XOFO torque-sensor motor. It appears to be well constructed except for the quality of the cable that goes through the axle. This week my second replacement motor failed at the top of a 300 foot hill climb. Checking with a multimeter I discovered that the Hall ground wire shorted with the phase wires. It seems that the plastic insulation on the wires is not durable enough to handle the heat generated by the modest amount of current that the controller puts out, around 14 amps max. In contrast the Heinzmann motor on my Europa withstands crazy amounts of heat generation during long hill climbs without failure." Later: "I have had problems with the Hall sensor wires shorting with the phase wires inside the motor on all 3 XOFO motors that I have tried. The vendor said that this problem has been fixed, but if you get one I would recommend checking the wiring inside." Does the Bafang look the same inside?
Nusse
Joined
Last visited
