Local Doctors
In Edinburgh 20% of GPS are due to retire in next 4yrs. Government plan. Don't tell anyone and hope Sent from my E6653 using Tapatalk
Local Doctors
Yes and no. As a Gp we are always trying to find the right balance between access for pts today and then to review them when needed. Every demographic has different needs. Some people can cone at any time and other pts need to schedule with work. All of this is offset by how many Dr's you have to use and if you can get someone else to see them. Ie conjunctivitis can be dealt with by optician or pharmacist. We have tried phone triage, only on the day appointments, we are still trying to get the balance. All of this against finishing on time to collect kids. Then login and do admin. Happy days. Sorry dave but ask your gp for how can book, some allow you to book appointments online Sent from my E6653 using Tapatalk
Battery help
Thanks again. I think Jimmy and I totally underestimated the power of a peg perego gator truck! Sent from my E6653 using Tapatalk
Battery help
I think they were Panasonic NCR18650A Sent from my E6653 using Tapatalk
Battery help
Thanks, aim is to make 15-18ah so should be 5p. Current is only high at start off then drops away but was enough to impress jimmy and fry his first battery! Will go with Sony Thanks again Sent from my E6653 using Tapatalk
Battery help
Hi, looking for guidance for a new battery. Jimmy from Insat has suggested the following options. We have tried one battery but current too high and it died rapidly Really appreciate your expertise The battery is to power a kids ride on truck. So needs to be safe. The current demand could be as high as 50A, then the cells I would have used would have been Sony VTC5 (2600mAh 30A), VTC5A (2600mAh 35A), VTC6A (3120mAh 30A), Samsung INR18650-25R (2500mAh 20A), LG HE2 (2500mAh 20A) Sent from my E6653 using Tapatalk
Dash cam recommendations
Fair point clearly made Sent from my D5803 using Tapatalk
No screen makes it smaller and more discreet. I hope to only use if in accident so would take card out put in comp and away you go. Horses for courses Sent from my E6653 using Tapatalk
I have a thinkers f50. V easy to use. Set up is simple, plug in micro sd and amend settings and put back in and forget. I have switched off GPS. Image is great, full HD. Fitted £75. Sent from my D5803 using Tapatalk
Hub verses External gears for mid drive
Any views on sturmley archer? Was considering a 3 sp with bbs2. Also wondering if the drum brakes have enough stopping power for an e bike? Sent from my D5803 using Tapatalk
Battery help
Thanks for all your help As for 5yr old I favour the safe approach. And plug and play recharging Average 18a and peak 30. Thanks again Sent from my E6653 using Tapatalk
Battery help
I haven't found a simple plug and play Having looked at the hobbyking option I would need to join a few together as I would like at least 10ah. Is charging this easy? Sent from my E6653 using Tapatalk
Battery help
Thanks for your help Sent from my E6653 using Tapatalk
Battery help
Hi, I am looking to pimp my 5yr old peg perego truck, it currently has 12v sla. I am looking to change to Li and need help for you to recommend who can make custom 18v battery and bms to fit in existing spot. height 4.5 inch / length 6 inch / width 4 inch Thank you all in advance Sent from my E6653 using Tapatalk
Mosso 29er 750w BBs02 first impressions
Thank you for your review, really helping me try to make my mind up, any thoughts on difference between this and the cube version? I am looking for an easy commuter, not so much an off roader, does this seller do such a bike or would I be better with the Kalkhoff. Thank you for your help
big_gems
Joined
Last visited
