Recommend me a new front light
I just bought a Solarstorm X3 (triple front light). They throw in a free rear light. I had a Solarstorm before, but I accidentally gave it 50 volts, and it's dead. Oops. The listing says you also get a 4x18650 battery pack (but I think without batteries). 6600 lumens. It hasn't arrived yet, so I can't say how good it is, but it looks too good to be true at £2.99. That's the nice thing about paying via Ebay/Paypal. If actually is too good to be true, I can get my £2.99 back. http://www.ebay.co.uk/itm/Solarstorm-X3-CREE-U2-6600Lm-Mountain-Cycle-Bicycle-Light-Bike-Front-Lamp-Torch-/162391524356?hash=item25cf4a0404:g:hqUAAOSwx6pYnmlV
sods law
I had a similar experience. It all started when I got stuck in a bog ... http://blog.drsolly.com/2015/02/bogged-down.html
Xiongda two speed whistle
Hmm. Is there an easier way to take the motor apart than unlacing the whole wheel?
My motor has done about 2500 kilometers, and I've been very pleased with it. Lately, it's developed a whistle. This only happens in the low gear, and only when I apply power. Can anyone guess what the cause might be, and do I have to take action? My guess is that this has to be to do with the clutch.
Hobby king multi star on offer
I just bought three more 10AH 4S, to make into a 12S 10AH pack. I already have two of these packs, and I'm very happy with them. Cost, £21.89 per battery, down from £42.62. Very good value! I'm using 2-4S chargers. They cost £6.61; I run a bunch of them off an old PC power supply. It means I can charge my 4S batteries via the balance port, no need to plug in the main power lead (but I do remove the harness that puts the three 4Ses in series, because otherwise I think I'd see a flash, a bang and lots of smoke). They only run 30W, but because I'm using three of them to charge my three 4Ses, that's really 90W
xiongda questions
I've done about 2000 kilometers on mine, it's a 36v model that I'm running at 12S, and I'm very happy with it.
Puncture-proof tyres for mixed on/off-road bike
http://blog.drsolly.com/2014/03/puncture-resistance.html
Best helmet IF you want one?
Yes, I wear that sort of helmet in winter. But it a hot summer, it gets a bit clammy in there, so I wear the usual sort of helmet with lots of slots and holes. I came off my bike yesterday (I was on very uneven ground), no damage done, and I didn't hit my head, so the helmet wasn't relevant. But here's the experiment that persuaded me to wear a helmet. Step 1. No helmet - bang my head on the road. Step 2. With helmet - bang my head on the road. I hear the arguments for and against, but that experiment convinces me. And if you're not keen on banging your head on the road, you can just do it as a thought-experiment.
Hobbyking 6S 16ah Lipo packs
Full marks for the battery box!
These 16ah, 6s batteries are not quite as cheap as the 4s 5ah hardcase batteries, which are 5% cheaper (comparing watt-hours). They are lighter, though, by about 25% (per watt-hour), which is very useful for aircraft; also useful for bikes. More importantly, they're in stock in the UK, whereas the 4s 5ah ones are currently not in stock.
XiongDa Two-Speed Motor
That's right, I'm using battery packs made up by myself from Hobbyking batteries. It means I have to make up quite a lot of soldered connections, but I don't mind doing that, and it does mean I get a 12s 5ah battery for £45. I wouldn't recommend this for an absolute beginner!
I love my Xiong Da. But one of the wires from the controller to the battery broke while I was in the field (literally). Those wires are very short on the controller they sent me, and although they are mulitstrand, they aren't 1000-strand like the 10awg wire you can get from Hobbyking. I'm constantly plugging and unplugging the battery, so this might not affect you. I cut off the bullet connectors, added a length of 1000-strand 10awg silicone wire, and terminated with an EC5 (which is what I use as standard on my batteries and controllers, because they're easier to plug and unplug than the alternatives I tried.
What do you carry in your repair kit?
In saddle bag: Open ended spanners, bike multitool, pump, spare inner tube, puncture repair kit, fuses, spare wire, terminal connectors, 5v step-down board (to power PDA if need be), external battery for iphone (which also has a backup navigation system), zip ties, silicone bands, small front light (just so I can be seen), small rear light, toilet roll, bike lock In shoulder bag (this is my geocaching bag): small torch, multi tool with pliers, forceps, multitool with scissors, splinter remover tweezers, needle nose tweezers, flashing purple light (so that when I tempoerarily leave the bike in the dark in the middle of a forest, I can find it again), first aid kit, anti sting and bite applicator, pencil, biro, gel pen, spare batteries for PDA, folding money wrapped up well and well hidden, spare battery for torch, magnet, magnifying glass, string, spare shoelace, insulating tape, sellotape, rubber bands, notebook, hand wipes, waterproof for PDA.
Aluminium and Front Hubs
My XiongDa is fitted in a front suspension fork. But I had to use a car jack to widen them by about an inch. These are steel forks, I wouldn't do that with aluminium.
Broken wire
I was partway across a muddy field, switched on the power for a bit of help, and ... no power. I got off and had a look, flicked the switch a couple of times, changed the batteries, then I noticed - the negative wire from the controller to the connector that I plug the batteries into, had broken. This is the controller that arrived with my XiongDa two-speed. Looking at that wire, my first thought was, hmm, that's a bit short. Not a real problem. And when I looked at the broken ends, I thought, hmm, cheap wire. Well, an electric bike with no power is still a bike, so I pedalled for 500 yards or so, but while I pedalled, I was thinking, how to handle this? I leaned the bike on a wall, unplugged the batteries, and took my penknife to the broken lead. I stripped it back about a centimeter on either side of the break, twisted the ends together, and wrapped sticky tape over the join. My thinking was, this isn't going to make the problem worse, and just maybe ... Well, blow me down with a 24awg wire, it worked. After all the efforts I've made in the past to get the best possible joins, it turns out that just twisting the wires together was good enough to get me through the next six miles. A small roll of insulating tape has always been part of my on-the-road tool kit. Now I'll add a short length of 10awg wire.
drsolly
Joined
Last visited
