Dctyke
  1. Thank you for replying. anyone else out there, trek is a very popular bike brand.
  2. I searched the internet but still cannot find a straight answer. I there a conversion kit to fit a mid motor to a trek with a bb95 bottom bracket? If so who produces them. Everywhere seem to go around the houses then talks about other types of bottom brackets. I’ve seen a couple of vids showing trek bikes with bafang mid motors but they don’t say how they did it. Info much appreciated. dennis
  3. Mine is a barrel connector like the one in the pic, I believe it's five pin (need to check) however it's all irrelevant if I cannot find someone who has them to ask the the questions.
  4. Looks like this is the one, would anyplace in uk stock it? http://shellmax.en.made-in-china.com/product/MotmNqOJkSVw/China-Electric-Vehicle-Parts-LED-Display-Power-and-Speed-6-1-Possition.html
  5. my wife's French made easybike has a Chinese six speed display. Looks like most others with four buttons down the l/h side with power, speed, assistance setting etc. The four buttons are getting sticky very hard to work. Can I get a replacement and would a five speed work as most I've seen on bike seem to be five? Advice would be appreciated, can supply a pic if needed. Thanks. Ps tried easybike but no help.
  6. Many many thanks to d8veh for help in sorting the bike out. It was the pas at fault...... And the 2nd one was too and that put me off course. The 3rd was tested by d8veh prior to me fitting and was of a different design (big orange block rather than a tube end). I was at my wits end when that didn't work however after a 2nd look I noticed because it was a different design the chain guard bracket was interfering with it. After I ground 10mm off the bracket the motor burst into life!! Mrs dctyke is happy now, thanks again D.
  7. That would be really really good of you, I can send the lcd, controller x 2 and the loom. I will put money in the package. Will you be emailing your address to me? Regards Dennis
  8. If I could find your email I would have. What I was going to ask can you reccomended (or possibly sell me) a controller which does not require anything at the hub and a handlebar control to suit.
  9. D8veh, any chance you could pm me? Ta
  10. Then walk mode only works with the hall sensor pins in the position I wired them. If I try swopping the 5v and signal wire walk mode will not work. Today I refitted the original sensor that I thought was not working, it gives the same voltages as the new one. Does this mean the fault could be else ware. I've tried a replacement pedal assist sensor and controller with no luck. Is it possible the LCD could be at fault?
  11. I will try that. In the mean time something for you...... If I press the two middle buttons together on the C300 LCD the motor runs without me having to turn the pedals even though it has a pas sensor on the crank? Pic of LCD in earlier mail above.
  12. With the signal disconnected it remains 4.75 throughout wheel rotation. All of the plugs are unique and cannot be connected wrongly.
  13. I was hoping to not have to dis-assemble the rear hub and de-solder again. I am happy not to have the speedo working. The controller must run sensor less as it did work with the plug undone prior to me trying to fix the speedo. Somehow connecting the speed sensor with the new hall changed something in the controller. I have read about controllers that 'learn' connections, I am hoping to return it to as it was but have no idea how to.
