January 26, 201412 yr Author This website mentions the BMS ensuring the battery has about 1000 charge cycles. I don't think this implies that a counter is on the BMS though. http://ebikeee.com/2013/01/31/we-visited-the-official-bosch-ebike-training/
January 26, 201412 yr Author @ Trex - if you do happen to find that email I would be very interested in looking at it to see how they do it. The plastic matrix which holds the cells together is custom made and necessary to hold the cells rigidly in place. So to copy it they must have used a 3D printer or something. So far I think the best method for re-celling the pre 2014 batteries is to use the company I used and then connect up the BMS and pop it all back in the case.
January 26, 201412 yr "The special BMS makes sure that the lifetime of the battery is about 1000 charging cycle". How can it do that then? There's nothing it can do to improve the number of charges other than limit the current and keep the cells in the safe range of volts, which all BMS's do. Sounds very suspicious to me.
January 26, 201412 yr Author My guess is that the 1000 cycles is an estimate. Just found out when I started using my bike. It was from the start of December 2012. I de-restricted it in Feb 2013. so, approx full charge cycles as follows: Used 3 times per week on average. Usually charged twice per day so that makes 6 charges per week (full charge cycles) 12 months use from Dec 12 till end November 2013 (when I changed to another new 288wH battery) = 52 weeks. Therefore, approx 312 charges so far.
January 26, 201412 yr Author I just found this link. http://www.alibaba.com/product-gs/1611695646/Bosch_Replacement_36V_8_8Ah_electric.html They say that they use Samsung cells inside the battery pack. They are also a gold supplier so for them to pull a fast one is highly unlikely I think. I think they have done a bare bones copy of the BMS PCB. My guess is that they have left out the bits that aren't really necessary like the sounder and some other stuff. Minimum order quantity is 1 unit. The case is probably not as good quality as the original Bosch units. Also, This is only for the 8.8aH battery but I reckon you could get them to put higher capacity cells in there if you requested a custom build. I think it is worth going for at this price. It would be interesting to see how the copy battery performs against the genuine one.
January 26, 201412 yr Author And some more info - the copy battery BMS lets you run the pack down to 30V instead of the standard 36V which Bosch employ. This may lead to shorter battery life in the long term.
January 26, 201412 yr it could be that they did not copy Bosch but made a plug compatible as they said. The Bosch battery may have a data logger running on one of those smaller wires. Without tracing the yellow/green/purple wires, we just don't know. It may be worth the effort to check which pins on the charger have 42V across them, that will identify the remaining wire as the datalogger's. It could also well be that the datalogger is only accessed when someone runs the diagnostics. In that case, the plug compatible does not need a datalogger.
January 26, 201412 yr Author Just checked the charger with the voltmeter: There are three terminals on the charger. Whilst putting the red test probe on the centre terminal on the charger plug and the black probe on the terminal which goes into positive terminal on the battery the reading was 4.63V. When this was done on the negative terminal on the charger the reading was 4.94V. Any ideas ?
January 26, 201412 yr Author I think you are correct re: the data logger. It is essentially pointless with regards to the overall functioning of the battery so I guess the factory in China haven't bothered with it.
January 26, 201412 yr There are definitely 5 pins on the connector. You have pins 4 and 2 as positive and negative leads. Pins 1,3 and 5 take much smaller diameter wires (coloured green, purple and yellow. These wires are connected to the BMS - not sure what they do That looks similar to the Panasonic unit's battery setup. With that, counting from the bike's rear, pin 1 is current positive, pin 2 charging positive, pin 3 feeds the battery content information to the handlebar unit, pin 4 is the negative and pin 5 monitors the battery.
January 26, 201412 yr Author Seems to me like you have got it spot on flecc. I am also guessing that the BMS from the Chinese battery clone has cell balancing incorporated into it as well as the usual protection functions.
January 31, 201412 yr Interesting Are you saying the BMS fails & no longer allows the remaining good cells to be charged. Or The BMS kills the remaining good cells making the whole thing useless. I'm asking because in the past I've built RC packs (NiMh) using good cells from dead power tools. It's neither. The chip in the BMS simply shuts down whole BMS permanently after 5 failed charges (for whatever reason) There is no way to reset that chip , once it decides the pack is dead is nothing you can do to change its mind So you can find duff cell and replace it but the BMS will prevent charging (or rather the chip will) Worse still many packs are designed so the BMS runs off one cell all the time. Leave it on a shelf and that cells goes below 3v after a few weeks and whole pack is a write off
January 31, 201412 yr Author It's neither. The chip in the BMS simply shuts down whole BMS permanently after 5 failed charges (for whatever reason) There is no way to reset that chip , once it decides the pack is dead is nothing you can do to change its mind So you can find duff cell and replace it but the BMS will prevent charging (or rather the chip will) Worse still many packs are designed so the BMS runs off one cell all the time. Leave it on a shelf and that cells goes below 3v after a few weeks and whole pack is a write off Been reading about that too - the only work-around would be to salvage a working BMS from another pack or purchase a non genuine battery which will almost certainly not have the shutdown feature installed. Then when these cells deteriorate, replace with better quality ones. Makita and others will say its due to safety but we all know what they really want out of this.
January 31, 201412 yr Yes indeed just buy non matika branded packs. They often at least as good. And don't have the chip as it represents a pointless cost - y
January 31, 201412 yr Looks like the more popular down tube Bosch pattern battery has a minimum order of 10. I don't understand this alibaba stuff, so if one ordered 10 what would the final bill be delivered to a UK address? http://www.alibaba.com/product-gs/1634143121/Longer_service_life_36V_eletronic_bike.html
February 4, 201412 yr Author Hi Rob, I contacted about 3 suppliers of the Bosch style battery but they all sent me quotes for either a whole bike or a deep cycle lithium battery (!!) Despite me using the text in the subject line "Bosch compatible 8.8aH frame battery" and it linking to their product! I will try again and see if I can get a meaningful quote sent to me.
February 5, 201412 yr Author Just thought I would post an update on how the new re-celled battery is going. So far I have been using it at least 3 times per week for my 13 mile commute (26 mile total distance) into work and it is lasting per charge, about 15% longer than the 8.8aH conventional battery. A small improvement but definitely worth it for getting this extra performance for the price I paid. It would be interesting to try a re-cell in the future using 2.9aH Samsung SDI cells to see how these cells compare to the Panasonic NCR cells.
March 21, 201412 yr Hi all. I ll try to bring these http://www.gd-battery.com/products_show-240.html to Europe with some help of battery importer. Unfortunately Chinese won't sell smaller quantity than 10 pcs. I should get the quotation in few days. Then I'll test all batteries with my haibike xduro 2012 set. Its possible that chineese replacements might be more flexible for future recelling.
June 1, 201411 yr Author I got one Bosch compatible battery from this place: http://www.gd-battery.com/products_show-240.html They only sell to traders so I had to be a bit creative on that front. Also, they sent the battery as an electronic device on the customs form (it was very well packed) and therefore got around the customs rules on the marking up of lithium batteries. No doubt this was to save on the cost of shipping. Very happy with the battery - it works well and was over half the cost of a new Bosch genuine one.
September 15, 201411 yr http://tapatalk.imageshack.com/v2/14/09/15/34290c816d8d9b8852561ea69476b871.jpg Just started to test it. Initially it looks (quality of plastic casing) very similar to Bosch. Provides same range and behaves thermally prety much the same as genuine 288wh.
September 15, 201411 yr Very interesting service opened in Italy Aside from their major speed tuning for Bosch engine, now they offer recell service. Turning old bosch batteries into 600wh / 17A behemoths. http://www.speedup.altervista.org From my private mailing - the total cost should be around 600 euro.
September 15, 201411 yr Good find. I don't understand. If there's room for 50 cells in there, why don't Bosch put 50 in as an option?
September 20, 201411 yr Good find. I don't understand. If there's room for 50 cells in there, why don't Bosch put 50 in as an option? There isn't enough room, I quote - "The battery, which is owned by the customer, is emptied of the original cells are replaced and increased to 50 units resulting in a total capacity of 612 Wh / Ah 17 to 50% more capacity if the original battery is 400 Wh and equal 110% more capacity if the original battery is 288 Wh. To obtain sufficient interior space adds two guscietti side pvc that increase the width of 20 mm total."
