Tools for Bafang BBS01
or a hammer and screwdriver, which is what I'd use.
Just a note - the BBS units now come with a different outer lockring that you need an external bb tool to tighten.
Get a spanner type one (so it can clear the axle) and with "c" type opening (so it can clear the motor) - like this one.
I have a Park Tool HCW-5 Head/Crank Wrench to use for the M33 nut on the bottom bracket. It is not a great fit with the single hook spanner just working. Easily slips and can easily result in damage to the nut.
I am still looking for a better tool.
IIRC I looked at the HCW-17 but I think I didn't go with it as it is designed for different sized nuts.
Andrew
