July 29, 20187 yr I Got a new one in January this year and the design of a few things has changed. for one the battery now sort of side loads instead of clipping in. Which is better because my old Cs2 battery controller was getting beaten up by the battery and the plastic at the top cracked. The new one seems a lot more secure. as for the restriction. The password still works but yes the settings are no longer the same. I have no idea what i did (I pressed a load of buttons) but my bike now thinks i'm going 1.6 mph all the time. Which has the effect of removing the restriction. If you don't mind this let me know and i'll PM you the settings. In return if you could send me the default settings i might be able to figure out exactly which change worked as i foolishly did not record the defaults. Hey James, Did you ever find anyone to exchange with? If not I can share my original settings if you like? I'd like to work out how derestrict it, so let me know?
July 30, 20196 yr Hi, I recently bought a second hand Greenedge CS2 ebike with an Intelligent brand LCD controller and 36V 9Ah battery. Although I am very happy with the bike I suspect it’s capabilities do not comply with UK law i.e. the motor does not cut out at 15mph (25kph) but higher (around 20mph) and also the “walk mode” on the thumb throttle is not limited at all to 4mph but more like 20mph ! I have found I can achieve the 4mph walk limit by using the ”-” button on the LCD controller. I would like to return the controller to it's original settings for the bike but I don't know what they should be. Grateful if anyone can PM me the details. Thanks in advance.
July 30, 20196 yr Hi, attached are the instructions I also have a YouTube video of my settings which are default, except the max speed, which in the instructions show where it needs to be altered to 25 As for the throttle, it could be that your bike, like mine, was manufactured before the law changed, therefore the throttle is fine. I use - on mine for walk along mode. Hope that helps. Mines done over 1400km with barely any issues. Still use it twice a week, and I have 2 batteries, for those longer rides.
July 30, 20196 yr Hi, attached are the instructions I also have a YouTube video of my settings which are default, except the max speed, which in the instructions show where it needs to be altered to 25 As for the throttle, it could be that your bike, like mine, was manufactured before the law changed, therefore the throttle is fine. I use - on mine for walk along mode. Hope that helps. Mines done over 1400km with barely any issues. Still use it twice a week, and I have 2 batteries, for those longer rides. Many thanks for your prompt reply together with the video and the settings description. I will attempt to revert to to your original ones tomorrow and report how I get on. One other thing, is it possible to reset the odometer or is it like a car - not possible ? It's no big deal really but I just wanted to record my own mileage and not the previous owner's usage.
July 30, 20196 yr No idea on that one I’m afraid. I was wondering that the other day as I was going to work. Just checked mine and it says 1231km so I must have somehow zero’d it after a couple hundred km’s But no idea how
July 30, 20196 yr No idea on that one I’m afraid. I was wondering that the other day as I was going to work. Just checked mine and it says 1231km so I must have somehow zero’d it after a couple hundred km’s But no idea how OK, thanks
July 30, 20196 yr Ah, it's not so simple is it ! I see from your video that after putting in the 1919 code and setting the speed there are other parameters which are not in the description : CU l 15; HA l 1; AS 5 12; Hd 6 0; Hd p 0. Any idea what these settings mean ?
July 31, 20196 yr After putting in the 1919 code and re-setting the max speed back to 25km/h, I compared your default settings with a set of others shown in an earlier video on the subject. I tried changing the Hd 6 setting from 0 to 1. This kept the "-" button for activating the 6km/h walk mode but also set the thumb throttle back to the 6km/h walk mode also. I believe my controller is now back to its original settings (or if not very close to them). Not sure what the other parameters are for although I think the CU l 15 setting limits the current to 15A. One of the other settings (AS ?) might enable changing the number of power assist levels up to a maximum of 9. This is a pure guess from what I have read about the capabilities of the controller and I might be brave enough to risk trying to confirm this, although I would prefer written confirmation if I can find it.
