Coyote Connect (Halfords) - installing a throttle
Thank you for quick replay. Just thought it depends on wheel size etc. Is disc fixing to the crank a common problem ?
I would guess that the chain came off and broke the disc. Some are more brittle than others. I think the cheap plastic goes brittle with age. You will need a crank-puller to get the crank off and if you have to replace the sensor, you'll need a bottom bracket tool too, so best to get both:
https://www.ebay.co.uk/itm/Crank-Extractor-Puller-Bottom-Bracket-Remover-Repair-Tools-for-Bike-Bicycle/274449052384?hash=item3fe67032e0:g:LJQAAOSwmZde4zf2
  • 2 months later...
[ATTACH type=full" alt="WP_20170413_001.jpg]18719[/ATTACH] [ATTACH type=full" alt="WP_20170413_002.jpg]18720[/ATTACH] [ATTACH type=full" alt="WP_20170413_003.jpg]18721[/ATTACH] [ATTACH type=full" alt="WP_20170413_004.jpg]18722[/ATTACH] [ATTACH type=full" alt="WP_20170413_005.jpg]18723[/ATTACH] [ATTACH type=full" alt="WP_20170413_006.jpg]18724[/ATTACH] [ATTACH type=full" alt="WP_20170413_007.jpg]18725[/ATTACH]
Hi
Hi Jim I have one of these coyote electric bikes with one of these units same as in photos above ...on my bike on front hand brake there is a cable behind hand brake wire..red an blue ...where in that silver box unit does it connect ..many thanks
Your question doesn't make sense. You shouldn't need to go into that silver box (controller). I suggest that instead of asking cryptic questions, you explain what the problem is that you're trying to solve. Also, it would be better to start a new thread with the title "Coyote Connect brake wire" or something like that.
