Cytronex Trek reliability
Cytronex reliability
I have had one for several months. It has now totally displaced my Giant Twist (advert in next A to B if anyone interested) as it is lighter, faster and a great ride with or without power. The electrics have gone through several torrential downpours of monsoon proportions without the slightest twitch. The only thing I have had to adjust is the brakes to counter excessive wear on the pads. I thoroughly recommend the bike. It is what an electric bike should be - a helping hand on hills, a great ride without power, and generally faster point to point. I have managed the daily commute at an average of 17 mph over 8 miles including 500 feet of climbing. That's considerably better than I usually manage by car in the early rush hour.
That sounds great.
At the moment, on my shortest commuter route I travel 8.1 miles. It has about 1100ft of climbing and 650ft. of steep downhills. On my Wisper I average about 16mph on this (takes me almost exactly 30mins), the reverse direction takes about 26min, so about 18.7mph. It is hardest near the end, because at this point there is a real pig of a steep hill. Not as long as some of the others but a real leg killer, especially as it follows 3.5 miles of a steepish 650ft. climb! I'd love to try the Cytronex on something like this to see just how it copes. From what I've heard it could be good.....I'd like to think so.
Cheers, Phil
That's great Tagray, the Cytronex is obviously well suited to your needs and you are clearly the type of rider this bike is aimed at.
J:) hn
The Wisper though is both a over geared and supplied with a 'high speed' motor, which I guess is actually intended to work in a 22" or 24" wheel (i.e. 235+ rpm). The Cytronex although a 28" inch wheel is supplied with the correctly geared 175 rpm motor and since it is in the front hub has a full, wide range of gears for the hills. The hub is also of lower rolling resistance, which will be of increasing importance on the hills. .
Phil
Hi Phil
You are absolutely correct the Wisper motor is a high speed brushless motor, however it has internal radial gears that are changed depending on the wheel size so the motor on the 905 and 705 is geared to the 26" wheel.
The rolling resistance on a Wisper motor should be completely free as if there was no motor on the wheel at all. If yours is not completely free wheeling there may be a problem with the motor.
All the best David
Wisper 905 and 705
Hi Phil
I saw your post asking for confirmation of the speed of the 905 motor on another thread.
I double checked with Bafang last night, the 905 and 705 motors are 250w and 215RPM.
All the best David
I now have the Cytronex and can report that it has been 100% reliable - early days I know but in comparison with my previous electric bikes it has been remarkable. The Torq needed lots of tightening of bolts, adjusting to get rid of the fork judder, not to mention water ingress cutting the power. It even went back to the dealer to have an electrical gremlin sorted. Even the well made Agattu needed a new gear hub (not Kalkhoffs fault I know), the chain kept falling off until I oiled the tensioner, the handlbars always needed tightening so not exactly perfect.
The key to the Cytronex is that it is a well sorted simple bike with relatively simple electric bits added so should be very reliable - that is what I am hoping anyway and I haven't had to get my spanners out to tighten anything yet.
OK up to now it was 100% reliable but I have to report that the bottle cage holding the battery came loose today and had to be tightened. Now who put the cage on Trek or Cytronex? From this picture Trek Bikes | Bikes | Bike Path | 7.3 FX it looks like Cytronex. I do find that there is always something that needs tightening up on a new bike and this Trek has been very good apart from the cage.
I think that's possibly to be expected Hal, mountings designed for a drinks bottle holding a battery which is volumetrically much heavier. Probably a good idea for it to be routinely checked for security from time to time.
If that's all that ever troubles you on it, it will be fairly unique among e-bikes. :)
Now it has started you need to calculate the mean time between failures, on riding time alone mine is about 1.5 hours but improving quite quickly.
Thanks for the reminder. I've been meaning to check mine over. Surprisingly I found them all nice and tight - even the mudguards. :)
  • 1 month later...
