What conversion kit
Thanks. The dropouts are standard quick release 9mm with lawyers lips. So something will need to be filed with a 10mm axle.
Filing dropouts could be an issue (depending on how beefy they are to begin with), but I wouldn't worry about carbon forks per se. I suspect the torque applied during disc braking on modern machines will be condsiderably more than that generated by the hub motor.
Edited by ChrisBike
