May 31, 20196 yr Evening all, So i purchased a Carrera Vengeance E-Bike about a month or so ago, at first worked perfectly well but today i went out on it and the controller on the handle bars which usually light up red indicating which mode you're on today kept flashing red, there is still power to the controller but its flashing red instead of a constant red and i did notice less power from the motor, any ideas what this could be? Thanks
May 31, 20196 yr Probably got water in it if you've been out in the wet or one of the wires has been pulled off the PCB. When the controller doesn't get a signal from it, it defaults to level 1. You'll probably need a new panel so take it back to Halfords.
November 15, 20205 yr Probably got water in it if you've been out in the wet or one of the wires has been pulled off the PCB. When the controller doesn't get a signal from it, it defaults to level 1. You'll probably need a new panel so take it back to Halfords. hi..I currently have this..could you please tell me what a panel is please?..is it the controls on the handle bar which is used to switch the motor on and also control the speed. What does PCB stand for?.
November 15, 20205 yr hi..I currently have this..could you please tell me what a panel is please?..is it the controls on the handle bar which is used to switch the motor on and also control the speed. What does PCB stand for?. It might be better to describe your problem. What exactly do you have and what bike is it?
