Gtech battery problems
Oh no! That does sound a bit terminal. Gtech might be able to help but I wouldn't hold my breath! Good luck!!
Gtech don't do any bike support anymore. It's was all done via cycle republic :( Sole distributor.
They did sell v2 and v1 cages and batteries (its a lottery which one you'll get even when they order the correct part - sigh).
You need both the new v2 bracket and also the new v2 battery holder. Bracket needed as well as the v2 battery holder - the battery retention clip is different on each. On your v1 frame only one screw hole is in the right place for the v2 holder but it's not an issue and is not over strained.
I have two v1 batteries (Both in surprisingly good health :) + v1 holder I could let go of...
Edited by thingi
I’d certainly be interested in buying a V1 battery from you, can you email me at Mefmotorsport@btinternet.com
The Battery holder + Bracket are dead simple swap out. Just inside the frame near the bottom bracket there's a standard (nine pin DIN?) connector plus a single lead for the pedal sensor (which is also inside the bottom bracket) the other cable leads to the motor.
Don't be afraid of them, on the new battery holder there's another nine pin din connector so it is a simple swap out and cable ties are all that's needed (that rubbery epoxy stuff comes off real simple, not scary at all).
Sent you a pm in case you just want a v1 battery instead. Since you do need a new charger to go v2 - luckily I already had one from my v2 battery mtb that I have as well as the city model.
Edited by thingi
  • 1 month later...
The usb connection will be for powering usb devices (such as phone used as satnav).
USB voltage would not be useful for charging from car.
I can't access the usb port when the battery us on the bike so I cant use it for phone navigation. If I try to use it to charge up ,say, headphones, when I stop, the battery just turns off.
I am also having a problem with my gtech battery , when we contacted the seller they want to take the battery and charger for a week to test. But we live in Spain. My problems are similar to other people's. Sometimes charging sticks at a random percentage, sometimes it doesn't seem to charge at all, but the biggest bugbear is that when I stop or if I want to change from eco to max, it just wont switch off or change. Turning on takes quite a few seconds too. I am an old fart and to go to max I cannot afford to cycle onehanded, pressing the button and not looking at the road for the time it takes to, maybe, change power setting. Very fustrating. I certainly cannot afford a new battery! Yes to the person who suggested listing problems and their solutions.
Have a slightly different problem with battery pins on a V2. Just through normal use one of the pins on the battery base bent and then lost contact And would not charge. This first happened when the bike was 8 months old, returned to Cycle Republic, they had the bike, battery and charger for around 3 weeks. On return all seemed OK, now it’s happened again and Cycle Republic closed, I now wonder if they just repaired the battery. Bike is now 18 months old so trying to get through to Halfords. Happy with bike but this connection problem with simple battery pins on a sealed unit costing £300 is Extremely frustrating.
  • 1 month later...
Looking at a V2 battery holder swap it all looks simple except for the small wire to the pedal sensor, does anybody know the procedure for pedal sensor swap, what needs to come apart?
There is no need to change the sensor, just the v2 battery holder (and it's bracket, two separate items BOTH are required for the swap). then it's just a simple matter of connecting the new holder to the current cable at the crank (there's a hole in the bottom of the frame for this purpose, it's dead simple).
Thanks thingi for your reply
In case others read this please note you can't see the crank sensor connection from the outside, it's poked inside the bike frame but a long enough cable to pull it out and disconnect it, looks like a smaller version of the hub cable connector.
Yup, indeed the sensor connector does look like a small hub cable connector, it's also possible to sniff the sensor readings / send fake readings to the battery / controller via a Raspberry Pie Zero or Arduino to de-restrict and/or make push button powered any of the GTech ebikes (it's bollocks that they aren't moddable).
I've not done mine yet... but the PoC worked.
Do you have links to any useful info?
https://learn.sparkfun.com/tutorials/how-to-use-an-oscilloscope/all
https://circuitdigest.com/microcontroller-projects/arduino-waveform-generator
https://www.hackspace.org.uk/ = advice & probably some help + access to stuff you don't have already or want to buy (google hackspace + your closest city if none on the list are close to you, the list is far from complete).
Edited by thingi
  • 4 months later...
  • 3 months later...
Removing the battery and replacing it on the charger does nothing, it remains stuck at the same percentage. The only way I have found to remedy this is to go on a very short ride, just a few yards, and this seems to reset the battery and putting it back on the charger will get it charging again. BUT, the funny thing is the battery must have been fully charged all along, as in about 5 minutes it will register 'FULL', when it couldn't possibly have charged from a low percentage to full in that time.
My 2017 Gtech Sport had a similar problem It would only charge to 90%. So, I tried what the poster suggested, took it for a short ride, using both eco and max mode, it is now charging to 100%. But it is charging rapidly, so I agree, I don't think it was actually at 90%, but probably at 100%, just not displaying that on the screen of the V2 battery.
