June 1, 20205 yr Can anyone recommend a simple stand (just for storage and washing) my Cube MTB it has 2.6 inch tyres the ones i have found so far only fit tyres up to 2.3 inches.
June 1, 20205 yr Can anyone recommend a simple stand (just for storage and washing) my Cube MTB it has 2.6 inch tyres the ones i have found so far only fit tyres up to 2.3 inches. I made one out of CLS timber (I think 63x38 but might have other sizes as well) and a few screws. I am lucky enough to have a 255mm mitre saw which makes short work of cutting and angles. If I wanted to use it for washing as well as a dry stand, I'd put a few layers of varnish or other waterproof treatment on it.
June 2, 20205 yr Author I made one out of CLS timber (I think 63x38 but might have other sizes as well) and a few screws. I am lucky enough to have a 255mm mitre saw which makes short work of cutting and angles. If I wanted to use it for washing as well as a dry stand, I'd put a few layers of varnish or other waterproof treatment on it. Thats a great idea why did i not think of making my own thanks
June 2, 20205 yr This is what I made: Could do with being slightly wider - the bike needs to be pretty straight in. Also, some of that timber is biggern than 63x38. It holds the front wheel very securely. I had no idea how well it would work - just created out of near-scrap pieces. I am sure anyone could make improvements to it. Edited June 2, 20205 yr by oyster
June 2, 20205 yr Can anyone recommend a simple stand (just for storage and washing) my Cube MTB it has 2.6 inch tyres the ones i have found so far only fit tyres up to 2.3 inches. I’ve got one with two hooks that hook into the rear triangle But the best accessory I’ve added to my mtb , also a Cube, is a prop stand.
June 2, 20205 yr Improvisation is genius and cheap, I did exactly as you have done Oyster but not a bike stand. I made a wheel truing stand for my wheel builds and works amazingly well, I should really build a Mk2 prepare it and varnish it.
June 2, 20205 yr Same thing here..I made a stand out of old timber even though I have one of those big metal repair stands I got from LIDL. Mines a bit different in that it supports the bike by it's bottom bracket, that means I can run the motor and turn the back wheel. Amusingly I can set the display to cruise twist the throttle and just let it run on it's own, that's probably got a use but I just do it for the heck of it.
June 2, 20205 yr https://www.ebay.co.uk/itm/Willworx-Bike-Super-Stand-Bicycle-Superstand-For-MTB-Hybrid-Road-bikes/324171945850?hash=item4b7a27577a:g:3-wAAOSwOINex~QX think i paid 10 quid for mine. https://komodosports.co.uk/komodo-bike-floor-stand-storage-rack.html
June 2, 20205 yr Cruise mode is just that no throttle or pedal required, ok I suppose for the M25. Cruise control is like a weird shaped tool, it's got it's uses but only rarely. There are times when it's come in handy as I like to use a throttle a lot I must admit.
June 2, 20205 yr Author https://www.ebay.co.uk/itm/Willworx-Bike-Super-Stand-Bicycle-Superstand-For-MTB-Hybrid-Road-bikes/324171945850?hash=item4b7a27577a:g:3-wAAOSwOINex~QX think i paid 10 quid for mine.[ATTACH type=full" alt="DSC_0063_01.JPG]35851[/ATTACH] https://komodosports.co.uk/komodo-bike-floor-stand-storage-rack.html What width are your tyres ?
June 2, 20205 yr What width are your tyres ? 2.35 but the hole is 2.45inc might get it in there if you let some air out the tyre.
June 2, 20205 yr https://www.bikeinn.com/bike/xlc-vs-f01-bike-stand/137432894/p?utm_source=google_products&utm_medium=merchant&id_producte=10138469&country=uk&gclid=CjwKCAjw8df2BRA3EiwAvfZWaF74-N22vtFziiC5_jC_2v8XIgDYF_mSylBvuvL_lLzp-o3pvyMg4BoCc0cQAvD_BwE&gclsrc=aw.ds https://www.deporvillage.net/xlc-vs-f01-unistage-bike-stand?gclid=CjwKCAjw8df2BRA3EiwAvfZWaBCJ7RUB2kLcSwLHe1t_lYnKMP27Ze0VUVxL65h6J1eeJh01VUfHPRoCF4AQAvD_BwE A BICYCLE, TIRE WIDTHS UP TO MAX. 70 MM / 29 "
