March 10, 20215 yr I just listen to podcasts and chill. Can you hear traffic at the same time? The issue of modding is painfully debated here and could result in criminal prosecution or a civil lawsuit from your victim after an accident. Over 15mph in the cold air hurts the face more. Rain starts to sting too. Personally I don't think it is worth the risk or aggro. I came to the same conclusion. If you think that discussion about modding is lively, ask pedelecers if helmets should be mandatory.
August 11, 20214 yr Hi, I'm looking to purchase this bike. I was wondering if the 2021 model will be worth it as I don't have a massive budget and need to be sure this bike will be ok.
August 11, 20214 yr Hi, I'm looking to purchase this bike. I was wondering if the 2021 model will be worth it as I don't have a massive budget and need to be sure this bike will be ok. It's still all the standard stuff, so nothing to raise any concerns. The only negative point I can see is the gearing. A 14 tooth top gear is too low for an electric bike. It'll be annoying after a while, but £20 to £25 gets you a DNP freewheel, with 11T, which will fix it if it bothers you. The 8.8 Ah battery is a bit small by modern standards, but replacements and upgrades are readily available when you can afford it.
August 12, 20214 yr It's still all the standard stuff, so nothing to raise any concerns. The only negative point I can see is the gearing. A 14 tooth top gear is too low for an electric bike. It'll be annoying after a while, but £20 to £25 gets you a DNP freewheel, with 11T, which will fix it if it bothers you. The 8.8 Ah battery is a bit small by modern standards, but replacements and upgrades are readily available when you can afford it. Thankyou for your reply, I will certainly look to upgrade in the future. I will look into the DNP freewheel change for sure. With a replacement battery it will be difficult as it's semi integrated. What would you recommend?
August 12, 20214 yr Thankyou for your reply, I will certainly look to upgrade in the future. I will look into the DNP freewheel change for sure. With a replacement battery it will be difficult as it's semi integrated. What would you recommend? It's a standard battery that they put in many bikes. You can get them from lots of suppliers.
August 12, 20214 yr It's a standard battery that they put in many bikes. You can get them from lots of suppliers. Do you have any recommendations? I am extremely new to all this.
August 12, 20214 yr Do you have any recommendations? I am extremely new to all this. They're called Dorado batteries. Use Google.
August 31, 20214 yr Author The walk mode is literally that. Set from 0 to 1,2, or 3 then twist the throttle. It will drag you up a hill nicely.. but at walking pace.
