June 18, 20205 yr Hi all need some advice does anyone know what tool i need to adjust the freewheel on a voilamart the two pin thanks
June 19, 20205 yr Park Tools cover most types. have a look at: https://www.parktool.com/blog/repair-help/freewheel-removal-and-installation
June 19, 20205 yr The two dimples are to dismantle the freewheel, not to remove it, unless someone has fitted an old freewheel that has the castellated slots for the two-dogged removal tool. To remove a normal freewheel, you need the normal splined tool, but you need one with a large hole all the way through it to clear the axle. If you have a 14mm axle, you'll need something like the DNP freewheel removal tool. https://cdn.shopify.com/s/files/1/0412/5529/products/FREEWHEEL-TOOL-1600_1200x1200.png?v=1460454029
