July 24, 20205 yr Hi all i found out what was the issue with my bafang 1000w mid drive it was the nylon gear when my friend took it apart he found out it was the nylon gear was stripped but i know there a different versions of bafang nylon gear can any one identify which one i have here is a picture
July 24, 20205 yr The BBS01 and BBS02 both changed, but I don't believe the BBSHD did, so all BBSHD ones should be correct. Luna make a steel one if you want to avoid the problem in the future.
July 24, 20205 yr Author I heard the steel one is very load and thanks for confirming that it is BBSHD
