August 19, 20205 yr Afternoon all. I am nearing the final fit and tidy up of a Yose Power rear hub onto a hybrid bike. My question is. I have 3 unused sockets on the wiring loom. 1 for the thumb throttle (my wife is not going to have it too easy) and 2 for the brakes (the bike has combined brake and gear levers) How do I waterproof these 3 unused sockets? I have bought some amalgamating tape from toolstation. I can see the principal behind it, and i can see how you could wrap it round a joint. But I cannot work out how to wrap it round an end. Any advice will be gladly received.
August 19, 20205 yr Use heat shrink first leaving it long then fold the end back on it self after that you can put a couple wraps of amalgamating tape around.
August 19, 20205 yr I use the Bafang BBS end caps - which are usually discarded after a kit installation. May be these would work: https://www.ebay.co.uk/itm/M4-M5-M6-M8-M10-M12-Black-Plastic-Dome-Bolt-Nut-Protection-Caps-Cover-Hexagon-01/162725704664
August 19, 20205 yr If possible, try and keep the connectors pointing downwards once sealed. That way any water that does get in them will drip out. Obviously keep them out of any road spray from the wheels wherever possible
August 20, 20205 yr If you can't find plugs at those China online pages, just "Silicon" them. That might even be better. And if visible, you can wrap some nice tape around it after. But with a bit of practice and tlc one can make beautiful silicon sealing plugs as well.
August 20, 20205 yr Use shrink tubes with built-in waterproof sealing, you can get them on Amazon (is there anything you can't get on Amazon?)
August 20, 20205 yr Author Thanks for all the advice. I had some bits of heat shrink in the garage so used/folded then wrapped. But when I fasten them into place I will also make sure they will "drip dry"
