Batribike replacement battery
I have recently purchased an batribike diamond pro. Unfortunately it requires a new battery. I dont have any idea where to start looking and as the online batribike shop is out of stock, I thought maybe I could buy a compatible battery. I am unsure as to where I would find one . Any help would be greatly appreciated . Thanks
Show a picture of your actual bike, as there are differnt versions. In particular, show the control panel and the battery.
In principle, you can use any battery you want of the same voltage. There are hundreds of low cost options. You can get your battery re-celled, but that's relatively expensive compared with replacements.
We always recommend when buying a used bike to bare in mind the cost of a new battery and deduct from the purchase price, there is no knowing if the battery is on it's last legs. Buyers can often get caught out and most sellers have no idea what so ever about them.
Hi i have a Batribike Granite, it too is an old model when i bought it and Batribike do not stock batteries for them. Ebay is your answer one company uses the shell of your old battery and put new cells in. My battery will cost £330 when it needs replacing.
a1motorsavers on ebay same battery as me
Thanks Sandan . Unfortunately I have looked on Ebay and can't find this seller .
[ATTACH type=full]43135[/ATTACH]
Thanks for your assistance . I will get my old battery recelled . I have found the ebay shop you mentioned .
