August 16, 20214 yr I have been messing about with carrera ebikes for a while now and all the previous controllers had data lines but would work fine without them attached to the battery. I have come across a vengeance 2.0 setup and I don’t have the correct battery or harness and all I get is error thirty three. which is down to data lines to the battery. I do have carrera batterys with data pins and a older loom but the data lines are on a different plug and defo different colours. Do any of you chaps know what wires are the right ones to join to each colour. ? There’s a pic of the only two spare plugs im assuming the two wire one is the unused lighting option that’s on all their bikes and a pic of the loom off it’s predecessor. The torque sensors are different plugs too but identical. So these probs will work with the right colours joined lol
August 16, 20214 yr I'd chuck the controller and torque sensor arrangement and fit a KT controller with normal PAS and throttle, then you'd be master of your own destiny.
August 16, 20214 yr Author I'd chuck the controller and torque sensor arrangement and fit a KT controller with normal PAS and throttle, then you'd be master of your own destiny. I couldn’t agree more lol I just want to test the parts prior to selling them as they go for good money at the minute specially when halfords ain’t got any in stock lol
