Fiido l2 indicator blinking 7 times
Hi , I have fiido l2 , recently it's back tyre got puncture and I did patch it but after assembled the tyre indicator flashing 7 times, I have checked on fiido site they said "Flash 7 times: the phase line is faulty". I don't know how to fix it, please help me to repair it.
Thank you.
It sounds as if you've pulled the motor wires when fixing your puncture. The phase wires are the three thick wires that run from the controller to the motor.
This video shows the newer Fiido model L3. Your older L2 will be similar. The phase wires are green, yellow and blue shown. AFAIK, there is no connector between the controller and the motor - it's wired directly. If the wires are well connected at the controller end, then you'll need to open and check the connections at the other end in the motor itself.
If it has the two part water proof motor connector, check that the motor connector is pushed fully back together properly other wise one will not get the proper phase /hall wire connection.
Other wise one will have to inspect the wire entry into the motor for damage.
