Evercross ek30 pro
Hi anyone know where I can get a evercross ek30 pro controller from evercross company not interested
If the motor has the standard 9-pin connector, the battery connects to the controller with only two wires and you have a cadence pedal sensor (not torque sensor), you can use any controller you want. If you show what you have with all the connectors spread out so that we can se them, we'd be able to give more specific advice.
Why do you want to change the controller? If you think it's broken, how did you ome to that concluion?
