Battery conditioning
Laxey Clive
17
I have my Pro Commuter bike and I'm well pleased with it, but the realities of work/weather/general life and my intended use of occasionally bimbling around locally mean that running the (36v 16ah LIon) battery completely flat will take forever in (my) normal use.
Mindfull of the advice that the battery should be conditioned by being completely flattened at least twice for it to give best service I am wondering - how?
If the bike had wired in lights I could simply leave them on, but it hasn't.
I do have an old fashioned caged bulb inspection lamp lying around though and I wonder - if I cut off the plug and carefully jury rig connections to the batteries female connectors will this work? The bulb should glow (however feebly) and so should drain the battery, or am I being naieve? Would I risk damaging the bms? Are there other risks involved? I should add that I am generally safety concious and would do this carefully and with me keeping obs.
Any advice welcome.
Clive.
tillson
5,253
3,197
Any advice welcome.
Clive.
You have to dump 576 Wh of energy (36A x 16A). Typically, incandescent bike lights burn about 1 watt, so it will take 576 hours, or 24 days to flatten the battery using the lights alone!
I think the safest way to condition the battery is to just go out and ride up and down hills until it is flat. It only need to be done twice, doesn't need to be done in one stint and won't take up a massive amount of time.
eddieo
Banned
Jul 7, 2008
5,070
what make is a " Pro Commuter bike " :confused:
Laxey Clive
17
Tillson, the lamp in question is not bike lamp, but an old fashiond 240v mains lamp. As I said the bulb will only glow feebly! Unfortunately 'riding it flat' twice isn't an option, I seek some static means to this end!
Eddieo, Pro Commuter is the brand. Think it might be similar to a Juicy.
Clive.
z0mb13e
578
Dorset
I have hung my bike from the garage ceiling and jammed the throttle open and left the bike to run itself down. Takes a good few hours as the motor is running without much load.
NRG
2,592
10
Lithium batts do not need 'conditioning'!
The only point to running it completely down and giving it a full charge is to reset any 'fuel' gauge that may be present in the BMS.
overlander
532
42
Wish i had your problem :D flatten my battery 2 times a day with my 40 mile commute. Trek also recommended 2 full discharges but as previously mentioned this was to calibrate the fuel metre.
overlander
532
42
I think you should also thin about when a manufacture says you get 500 cycles does that include partial charges. From what you say you will be charging from say 75% up to full does this count as a full charge. If that was the case would it not be better to run the battery to 25% and then charge it, just food for thought.
NRG
2,592
10
Cycle life is based on full cycle charges, you should get far more part charge cycles. Infact the advise is to charge little and often, you will still be stuck with the natural life of the battery so plan for replacement around the 2~3 year mark.
tillson
5,253
3,197
Clive.
It's your choice, but I would be hesitant to connect any load to the battery other than the motor via the BMS. zOmb13e might have the best solution to your predicament.
overlander
532
42
It just does not feel natural, i am so used to charging batterys when they are dead. Glad of the info i find on this forum as i will now charge up more often especially at weekends.
WALKERMAN
269
I have checked my ProConnect two year old battery. The 10 second test showed 3 lights. This means that the battery is failing after exactly two years and only 384 charges as I charge it every night. (48 weeks x 2 x 4 days = 384 charges)
I don't let it run flat but charged it from two or three lights so that hasn't really extended its life span.
overlander
532
42
The batteries really are the weak point on these bikes from a financial point of view. Still not bad in the big picture but could be better.
30,840
Don't forget to do full conditioning first to ensure your capacity check is accurate.
That means riding down to the LED fast flashing empty stage, not just the slow flashing, then a full recharge. I wouldn't be surprised if you then had at least a four LED capacity. It's also important to measure at a comfortable temperature, a cold battery will measure low, so overnight at room temperatures first is advisable for accuracy.
averhamdave
340
-3
I'm confused (frequent problem):
I have a new 36v 15ah Lithium Ion battery (duct tape type) on my bike.
So far it has only run about 5 times for about 20 minutes each time on average and I have recharged it each time I have returned home. It has never been anywhere near flat.
Have I done wrong? Do I need to run it flat a couple of times? This would be contrary to other advice I have received.
What's this BMS re-setting thing that's been mentioned.
I would really appreciate some concise advice from someone who actually knows as there seems to be some conflict in this thread (no disrespect intended to anyone). Thanks,
Dave
z0mb13e
578
Dorset
Li-ion cells shouldn't be fully discharged. They don't like it. Here comes the but...
Most devices that use Li-ion batteries are either charged (and monitored during discharge) by an intelligent circuit that keep the battery within safe limits.
All the Li-ion or lithium derivative ebike batteries I have seen have have the circuitry in the battery itself. The circuit serves to ensure the cells are not over charged or discharged and damaged.
So to say we discharge a Li-ion battery is true but only as far as the circuity will allow. If you discharged a Li-ion with a BMS and then left it stilling for months it may discharge beyond its design limits and may not take a proper charge after that - though that isn't always the case as I have resurrected laptop batteries that were totally discharged, thought they usually don't last more than a few months after that.
The circuitry in the BMS often have led fuel gauges. This is based on maximum and minimum battery voltages that the circuit records over time - how often and when is down to the designer. So the discharge/charge or conditioning cycle is really just to calibrate this gauge and make the lights more representative of the capacity of the battery.
The same applies to Li-ion mobile phone battery meters - if you replace an old phone battery, the battery meter is likely to be off kilter for the new battery and letting the phone switch itself off when the battery is low and then charge to full and repeat will reset the meter.
overlander
532
42
I thought the battery or controller would cut the bike out before damage was done. I find that towards the end of my commute no battery power is showing on the consul just a flashing battery outline but the bike is still assisting but weakly. I immediately put it on charge when i get home or work I do not let it sit about discharged.
NRG
2,592
10
It will as pointed out above, when we talk about a full discharge it is to the point where the BMS has cut power....the cells are not at 0 volts, there will be a voltage across them but they will have near zero capacity.
indalo
Banned
Sep 13, 2009
1,380
Herts & Spain
Yet again we have a thread due to concerns over battery life. If the damned things were priced reasonably, no-one would pay too much attention to their lifespan. At the first sign of deterioration, the battery would be replaced. It's only because the manufacturers/importers/sellers all conspire to rip off the consumers that we worry about battery life on ebikes.
It doesn't help that their friends on this forum continue to protect them by attempting to justify the indefensible using spurious statistics. I sometimes think that certain members of this forum are in the pocket of certain businessmen as I can't think of any other reason why any electric cycling enthusiast would want to agree with the industry on prices.
Indalo
theskip1
159
sm6
as has already been said lithium batteries do not need " conditioning " in fact running them flat to often can damage them over time. its best to keep them topped up if possible.thats why it cuts out before its compleatly flat by the bms.the only thing that needs to be done with a new battery is to balance it this happens after two of three charges if they are not to far out.youl'l find your phone battery will last a whole lot longer if you keep it topped up rather than wait till its flat before charging.
