Not as I understand it, it works in the same manner as other systems, the difference being the BMS can go into a sleep mode thus saving the battery from a slow discharge if not used for a while. Most other systems will continue to draw a small amount of power from the battery.
As our batteries are relatively small in capacity compared to cars top and tailing at 20% is not pratical as range will be severly reduced...but as mentioned in another thread the new Kalkhoff 18Ah battery is probably large enough for you to be able to have some sort of top n tailing of the charge / discharge to increase life alas it would have to be done manually.
