BBS02 ERROR CODE 30 - help needed
MrMark
67
Ysterday after a fiew minutes of riding I got an error 30 on the display and the motor cut off.
I have checked all wiring harness and connectors for damage or bent pins.
I have unbpluged all sensors.
I have removed the controller and fited it again.
The result is that nothing has changed.
When I turn on the motor goes for a fiew seconds and cuts off with error 30 on a dispaly.
I did not fit throtle at all.
Please advise me what else can I do.
16,494
6 things can cause error 30: throttle, brake sensors, speed sensor, LCD, 1-4 trunk cable, controller.
try unplugging one item at a time. When you get to the last 3, you'll need help of a friend who has the same kit.
3,986
The problem could be anywhere or everywhere in your electric system, so we have to use a bit of reasoning, judgement and analysis to get to the cause. Without additional information, there is virtually no chance of solving your issue.
Electric problems very rarely just appear by chance, so you need to think back to what changed just before the problem started, like a crash or bike fell over, a wet journey, an abnormal load on the motor, maintenace, and things like that.
Have a particular look at cable routing. Did you stress any cables? Did you pull the zip ties too tight?
MrMark
67
The problem is I don't know anyone with bafang motor in my area :/
Cables look just fine.
Is here anyone from Liverpool?
Day before I was riding in a wet condition but the motor worked fine as usual.
I have used special gel to protect cable connections. Bud ends from battery cable were treated with liquid tape.
Problem appeared after about 30minutes of normal ride.
3,986
How old is the motor? Most BBS01 and 02 are not waterproof, though the B version is better thanthe A. Do you have a throttle?
MrMark
67
I have it only for three moths. Well I heard that they are quite waterproof...
The controller was dry inside.
I did not use a throttle
minexplorer
532
93
55
Four Lanes,Cornwall
Did not use the throttle but still had it fitted in place? or did not fit it but left the cable end uncapped? if rain gets into the throttle and you havent opened it and sealed the wires to the hall sensor with some silicone. or rain gets in the open end of the cable....these scenarios many, inc me have suffered controller damage.
MrMark
67
I did not fit a throttle and a cable end was cupped and properly sealed. I have plugged in throttle for a test and it was working for a few seconds until the error appeared again and the motor cut off.
jarob10
270
83
51
Uk
Any signs of life with brakes & speed sensor disconnected?
8,238
30 is comms so simply the issue is a failed LCD, trunk cable or controller has a component failure. Most likely the latter due to damp/moisture.
Simple issues like brakes just throw up and easy 'error 5' to sort out.
If you get 12 before hand then definitely a new controller is required.
3,986
If you get a problem on the 5V rail, like water in the throttle or blown motor hall sensor in it can take out the whole 5V, which will stop the controller to LCD comms and give code 30. To confirm that, you need to measure the 5v on the throttle connector.
If you have 5V, there's a fair chance that a new controller will fix it. If you don't have 5V, you need to find out why.
minexplorer
532
93
55
Four Lanes,Cornwall
What in the end cap? Is it possible this could cause a short between the pins in the throttle cable, like rain can when uncapped? i mean the pins are kept from touching each other for a reason.When my throttle got wet it caused problems.when i detached it went away. BUT i didnt seal the cable end and more rain then caused damage to the controller shorting the pins.
D8ve on here also had an error 30 and it was the LCD. others have had it caused by the speed sensor faulty.
Fordulike
3,802
1,537
Check that the wheel spoke magnet is passing close to the speed sensor
I had this issue once, and the symptoms were that the motor ran at max. After drying out the throttle connector, the problem resolved itself, but it took me a while to figure out it was due to a drop of water inside the connector.
Might be worth checking the speed sensor magnet is passing close enough to the sensor.
8,238
In the past if a speed signal/sensor error, 21 is the only error I have seen.
minexplorer
532
93
55
Four Lanes,Cornwall
How are you getting on mark.has any of the advice enabled u to get to the bottom of the problem yet.
8,238
Error 30 via speed sensor will only occur if the 5v is compromised by moisture.
MrMark
67
Thanks a lot guys for all answers!
I am sorry I did not respond sooner but I had sort of family problem so I did not think about my bike and fortum itself.
I had a faulty conntorller befor and accually I had an error 12 before 30 apeared...
This time i did not get 12 at all.
I used dielectric grease It does not cause a short I am prity sure about that :)
Week ago I took a whole set of a bike I have not been touching it at for 7days. Yesterday I have chcecked an email from eclipse store and they told me to send the controler back to them for a test.
Just before I packed the conntroler I plug everething together and suprisingly all worked well! I turned the motor on with a throttle for an hour (I have done three short breaks) and did not see any error on a display. Today I am takinig a bike for a trip and will see how doeas it go but it seems like the controller is working normaly...
minexplorer
532
93
55
Four Lanes,Cornwall
I had the worst of the problem caused by rain rectify itself after a few days of drying out too.so thats probably what caused it. in my case tho some permanent damage had been done with no error showing.looks like u have been lucky.
peter.c
1,611
492
thurrock essex
Looks like it was dampness in the throttle or a connection :) I tape all the plugs and glue gun the cables into the motor and a plastic bag over the display if it is raining
minexplorer
532
93
55
Four Lanes,Cornwall
Yes i learned the hard way to make sure the hall sensor wires in the throttle are sealed with silicone. And never detach it and leave the cable uncapped which was what finished it off.The displays have never been affected ,no matter how wet they've gotten.so i think they are waterproof. Luckily i was still in warranty. Eclipse replaced the controller after testing it.
