BSSHD / BBS02 throttle only - would it make your chains snap frequently?
krzychoniusz
64
London
I recently came across this video where the owner of a bike fitted with a standard (not modded) BBS02 complained about chain snapping pretty much every 2-4 weeks if the bike was ridden with throttle only. Mid drive motor would definitely wear out the drivetrain considerably quicker than a human pedalling would do, but to me drivetrain rebuild every few weeks seems quite extreme. I haven't actually owned a mid drive yet so cannot verify if what he says is true. Can anyone confirm? Is riding a powerful mid drive on throttle-only really such a bad idea?
peter.c
1,611
491
thurrock essex
You can break any thing if it is abused or the chain line is out, in normal use it is not a problem , others on the forum run high power bbshd without problems
tommie
1,760
600
Co. Down, N. Ireland, U.K.
The chain is much too loose, opening the throttle under those conditions would cause a violent `slap` on the chain.
If the chain is under a degree of tension to begin with the force of opening the throttle would be gradual, not instant.
Also use some of the stronger 7/8spd chains, like KMC, Wipperman etc...
Fordulike
3,802
1,537
You can program the controller to have a low start current, which would minimize drivetrain stress.
Reactions: tommie
krzychoniusz
64
London
Thanks, so it shouldnt be a problem then if a quality chain is used and optimal tension is maintained?
Do you recommend any source for instructions how to limit start current? I’m looking to buy BBS02 with LCD KT3
KirstinS
3,224
899
Brighton
I didn't think you could for the throttle, only PAS. On my bbs02 the throttle is brutal and I have a low start up to keep my hub gear happier. I mostly don't use the throttle and when I do I can feel and hear the bike complaining
wheeliepete
2,047
755
Devon
BBS02 will not work with KT3 unit, you need a Bafang LCD. Settings can vairy depending on vendor, so best to get a programming cable and go from there. Plenty of users here to help find best settings depending on your requirements.
Fordulike
3,802
1,537
I don't use a throttle personally, but there is an option in the software to change the start current to a lower percentage.
  • Useful
Reactions: krzychoniusz
