Can anyone recommend - 36v/350w/135mm/Juliet/36h compact rear hub motor for 16" wheel?
jahknob
Nov 27, 2019
As per the title, I have some experience with electric conversion kits for my Brompton, but not much else.
I'm trying to convert another 16" wheel folder (Mezzo), but this needs a rear wheel motor. Specs ideally would be 36v/350w/135mm/Juliet/36h compact (i.e. small hub diameter) rear hub motor for 16" wheel. Just need the motor. Presume I need a high RPM gearing for a small wheel?
I don't have the experience to know which brand/model would be a good bet for this application.
Any thoughts/help/recommendations appreciated..
j.
3,986
Q100H for free-wheel gears, Q100C for free-hub gears. You can get them from BMSbattery.com ir equivalent AKM motors from Topbikekit.com. I think Greenbikekit.com have them as well.
16" wheels come in two sizes: Chinese 305mm and Brompton 349mm. Check you bikes, wheel size if you're thinking of buying a ready-built Chinese one.
8,230
GBK do the small gbk100 series of silver hubs, look identical to Q100/AKM.
Also available is Bafang SWXH.
3,986
There's a new tiny Bafang cassette motor that I'd love to try, but I've not seen any resellers stocking it yet. It's on the new Ebco bikes
5,785
jahknob
Nov 27, 2019
Wait, think I found the rear version here:
Is this a good bet for what I want to do?
jahknob
Nov 27, 2019
Sorry - this might be correct link:
8,230
wheeliepete
2,047
755
Devon
Nice find there Nealh, good price if free postage is correct.
8,230
I just went to the payment and it came up Free shipping so not bad £147, buyers might need to budget another 25 - 30 for duty as it is couriered by DHL/FedE/UPS.
D2D is 6/7days.
42nm max is quoted but see they also mention it can give 50nm isn't too shabby for a hub and 11.1 gear ratio, 25a is the max current rating and only 2.5kg.
I'm also reading else where the freehub body can take up to a Shimano 10 spd cassette.
The planetary gears are like the Q128C and are a two stage nylon reduction gear and not a single stage gear like on the 5:1 hubs. 137 hub parts.
33171
8,230
The other thing is motor RPM you would have to inquire and ask for the RPM to suit your needs, for most 230- 250rpm in 26/28" wheel would be good.
Disk holes are blind so no water ingress here.
8,230
I think this is still not the tiny cassette hub motor that VFR mentioned, as Bafang do a smaller lighter 1.7kg G370.250DC hub.
https://flic.kr/p/WUiv2H
And my post crosses with VFR's reply.
8,230
It's 145mm D/O , H600/G370,250DC.
Also reading it might be as low as 1.4 kg in weight.
wheeliepete
2,047
755
Devon
I asked about diff. speed motors and they only do one, not clear on RPM, just said 25 kph, which isn't that helpful.
Edit;
Just came back with 12 or 13T winding, so 230/250 RPM, suitable for 26,700c and 28".
5,785
5,785
You are my savior! I have been looking everywhere other than ebike.ca where the same motor costs over $300 shipped. The only problem to solve now is magnets flying off at over 400 rpm (48v x 8.5 rpm/v = 408 rpm) - ebike.ca have a rotor with magnets re-glued with high temp epoxy. I wonder how hard that can be?
