Chinese conversion kits.
Hello, I'm considering buying a 48v 1000w rear hub cinese conversion, any info please. scor24
  • Hello, I'm considering buying a 48v 1000w rear hub cinese conversion, any info please. scor24
    Votes: 0 0.0%
  • Chinese conversion kits
    Votes: 1 100.0%
  • Total voters
scor24
11
Hello, I'm considering buying a 48v 1000w rear hub cinese conversion kit for a Dawes hybrid bike. Has anyone experienced these kits and are they reliable? scor24
8,226
How/where will use use the kit ?
On hilly terrain it will be pretty useless, they are usually wound for fast riding so expect 390 - 490 rpm, most batteries with these kits are woefully inadequate.
25/30a controllers which often these kits have really need a battery with pucker 15/20a rated cells in them as the drives are designed for high rolling speed and current draw to get the best out if them. At slower speeds below 20mph look for a geared hub for more efficiency.
The drives are D/D (direct drive) gearless drive and tend to be reliable, they are heavy 5.5- 6kg or so.
8,226
The 29E to be honest isn't to bad a cell not the best but by no means not the worst to use on an ebike.
For your needs with a D/D hub you need to be looking at the 30Q at least shame it's out of stock though, also shame they don't do it in 13s 5p config.
D/D hub kits need a high spec battery which costs a few more quid, the best place to go to is BGA/Insat with 30Q or HG2 cells.
I would say that either it's the wrong kit for your bike or you have the wrong bike for the kit. For your bike, a lighter kit would be better, probably with a cassette motor. For the kit, a cheapo steel framed bike with freewheel gears (7 speed or fewer) would be better. If you want to go 30mph, you need big tyres, hydraulic disc brakes and, ideally, full suspension too.
Don't consider one of those kits if you want to run it at legal speeds. It'll be very inefficient and there are much better kits.
nemesis
521
343
Have a look at what EM3EV have to offer,fantastic batteries and motors and very good to deal with.
I have two bikes with their kit on and they are used a lot.
Blunderbuss
158
22
Cambridge
I have the 1000W 48V setup you are describing and whilst it has plenty of power (I do all off road) as the other posters say it needs a good battery, so the whole setup is heavy. Even up the hills I rarely use above setting three on the controller (which shows 350 to 400w). So as advised in a previous post i am going to change for a 500w geared hub which is now on order.
scor24
11
I'd encourage you to look at geared hubs for "normal" to fast road use
Got mine from these folks, pretty impressed, though I do regret buying a 10Ah battery as its range is only just enough:
https://www.ebay.co.uk/itm/36V350W-26-Rear-Motor-with-Cassette-Electric-bicycle-Conversion-kit/222254726342?epid=1785746085&hash=item33bf69fcc6:g:C3IAAOSwdTJaXvku
Hi, I've had a look at that kit, looks quite impressive.
I see it's only a 26 inch wheel, my bike is a dawes hybrid with 700c wheels, so that might be the main problem with that kit.
Do you know of a similar kit with 700 wheels?
Thanks. scor24
scor24
11
Ok, I was looking at the kit https://www.ebay.co.uk/itm/36V350W-...746085&hash=item33bf69fcc6:g:C3IAAOSwdTJaXvku DynatechFan used. which only has 26 inch wheel whereby I really need 700c wheel, any advice.
Thanks, scor24
wheeliepete
2,047
755
Devon
You could re-lace the motor into your 700c rear rim, just need a new set of spokes, which are fairly cheap.. I don't think there are many kits that are under £200 delivered without looking at shipping from China which works out expensive unless you buy a bare motor. You still then have the problem of fitting it into a rim.
8,226
scor24
11
Ok, thanks.
As my bike includes the brakes and gears combined, I can't use the cut off brake levers, would I be right in thinking the motor stops as soon as you're not peddling with the pedelec system.
you can use a cable sensor:
https://www.ebay.co.uk/itm/1-PCS-HWBS-Hidden-Wire-Brake-Sensor-for-E-Bike/332586353476?hash=item4d6fb10344:g:EBEAAOSwAwFapz60
They only work one way round, so you have to check which end of the cable to put it. Also, the connector sequence might not be correct for your controller, so peal back the heatshrink to check the colours and swap the wires around if necessary.
Loads more different brake sensors you can use with lots of different connectors for different controllers to save messing about:
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.Xbrake+sensors.TRS0&_nkw=brake+sensors&_sacat=888
If your kit has a fast response controller, you probably don't need them.
