Factory Reset.
PeterPi
87
41
I changed the display from KPH to MPH and since then, although everything works fine, I get no speed indication. I've tried reverting to KPH but still no go. I've also disconnected the battery for a few seconds to no avail.
Is there a way to do a factory reset on the VLCD5 or are there any other suggestions?
Pete
gw8izr
224
240
Pete
I think in an earlier post you told us it was a crank drive?
If so has the magnet fallen off the spoke or moved a bit?
Reactions: PeterPi
PeterPi
87
41
It seems to be in the right place and I still get peddle assist, but I'll try again tomorrow. I'll remove it completely and see if it makes any difference.
gw8izr
224
240
On mine if I move the magnet everything still works apart from speed/distance information ( and any associated function of same )
Reactions: PeterPi
PeterPi
87
41
Yes, because I was getting peddle assist I assumed the controller was picking up the pulse from the hall effect. I tried it earlier with the magnet removed and as you say it still worked.
I reattached the magnet and all is working again, even in MPH. I think the gap is just about at the limit and I'm going to have to reposition the hall effect sensor and the magnet.
I wonder if it goes into a default, similar to the get you home "limp mode" on a motor vehicle.
Pete (GW4NFJ, QTH Swansea)
8,236
It the magnet gap it too large you could close the gap with another
small magnet on top of the existing.
Reactions: PeterPi
gw8izr
224
240
Good I’m glad that worked out, I did think that was probably the case because when I first set mine up I didn’t bother fitting the magnet in my impatience to have a quick ride up and down the street, the behaviour was exactly as you described :)
73 Paul
Reactions: PeterPi
PeterPi
87
41
73 Paul
Strange that it does that. Must mean that you can exceed the 25 KPH limit if its not on there.
