Hope Valves again sorry
Andy Grayland
I have a new Kalkhoff Agattu. What a great bike it is to. However I am suffering from the Hope valve problem. I bought an adapter from halfords so I can use my normal Schrader foot pump. This works but how do you measure your tyre pressure with a Hope or a Pesta valve? Any ideas?
Andy
30,404
Many gauges can show the pressure with Presta valves, but it can be fiddly if the top nut isn't screwed out the right amount.
It isn't possible to do a static measure with the Woods/Dunlop/Hope valves, since there's no way to release the air against a gauge.
However a dynamic reading is possible on the types of pump that have a gauge incorporated, since as the valve opens to allow air in, the internal and external pressure balance at low pump force and the gauge can be read at that point.
In this respect I prefer a stirrup pump with gauge which makes precise reading much easier than when stomping about on a foot pump.
ITSPETEINIT
492
Mere, Wilts
Your lucky day! (or is it?)
Andy
You measure the pressure inside a tube that has a Presta Valve with a Presta Valve Pressure Guage.
You have to take the Pump off the valve to do it - but at least one can take the pressure guage for a ride: that's more difficult and much less convenient with a Track (Garage) pump.
I have one and it measures lbs/psi (10 - 105) & and atmospheric 1 - 7.66 BAR.
It's yours for free (I no longer have Presta Valved Bike tyres).
Just let me know your address (PM me if you want to keep it from general publication). It will come to you "Post Free".
Regards
Peter
ITSPETEINIT
492
Mere, Wilts
Your lucky day
Regards
Peter
Sorry Andy, the bases of measurement are:
lbs/square inch (psi) 10 - 105
Kg/cm2 1 - 7.66 (This is not quite atmospheric bar)
The conversion tables are on the internet at:
Pressure Conversion Table - Transwiki
Regards
Peter
Andy Grayland
Thank you so much for your kind offer Peter. Unfortunately I have fonud that my Agattu has Woods valves not Presta type so It will be no good to me. I think from reading other threads that I should change my tubes for Schrader types. So does anyone know of a pump that fits in the Agattu spacing that will fit Schrader valves?
Thanks again Peter.
oldosc
207
10
small joke here they are not woods but Veillheim(c) Post passem))
One way to save a bit of money..dont change untill puncture..buy the adaptor (posts passem) go to garage with free air, use schrader /Veillheim adaptor to check pressure..about £1.5 no sweat (literally
