How on earth do I get the battery to fit?
Alib
13
51
Cornwall
ok, bought and installed the bafang 750w mid drive.
Now the battery is baffling me, it doesn’t fit into the water bottle slots so how on earth do I fit it?
Ali
16,460
you may need to install a couple of M5 rivnuts to your bike's downtube.
minexplorer
532
93
55
Four Lanes,Cornwall
Ali
I bought a shark cased battery for mine and had the same issue .Bottle holes to far down.I used a foot of inch wide steel strip .Drilled for a couple of m5 bolts high up for the bracket .An lower down for the bottle fittings.
Electric Bike Rider
7
Wales
or on the actual battery bracket itself can`t you drill a couple of holes so it all lines up?
This is probably a good idea if you don't like the idea of drilling into the frame.
Also, there might be a way of getting some straps around the downtube.
I don't reckon those bottle cage mounts are that strong anyway when holding a big battery. I have a bike where they have worked themselves loose on an alloy frame from the weight of just a water bottle.
I do not have a battery like this though so have never tried.
